putting together my own 2.5" level kit - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-14-2014, 07:09 PM Thread Starter
tuftruck 2.5" level coils 3,750lbs, $151.00pr
RANCHO Part # RS5043 2.5" level shocks $100.00pr
i'll be making my rear blocks, 4" tall, FREE
new rear U-bolts run about 10 bucks each at the local farm store.
i'm also going to get the front caster shims, but unsure on set that it need?
i'm wanting the adjustable set,
(-2.5 to +2.5) or do I need (0 to 4)
2006 f250 ccsb, 6.0l
unknown 4" SS turbo back with a muffler.
edge evo(unhooked) just a dash piece.
samsung tab 3 running- torque pro, gps, and music.
cool front bumper.
19?? F?50
1985 3/4ton frame
1986 1 ton axles kingpin dana60 10.25 rear
1995 body,
1995 EFI 4.9l (300) I-6 ported polished and cammed
1979 NP435 granny low with a custom built hydro clutch
1984 NP208 transfer case
Torque Monster
fordtrucknut is offline
post #2 of 7 Old 07-02-2014, 04:21 PM
skuzzitude's Avatar
Quoted: 14 Post(s)
Bump im wondering too
skuzzitude is offline
post #3 of 7 Old 07-14-2014, 08:32 AM
GotTorque's Avatar
What kind of ride did those springs give you?
Thanks
2006 CCSB PowerStroke
-PMM coolant filter and EGR delete
-Gearhead SRL tune
-5" Diamond Eye Exhaust
-20" BMF Novakane's 35" Toyo AT 2s
-All updated ford parts
-Chopped Running boards
-Gotta love the 6.0 haters...
GotTorque is offline
post #4 of 7 Old 08-19-2014, 08:14 AM
Looks like a good kit, let us know how it works out,
Thanks
I have a buddy who swears by the Tuftruck springs. He says the ride does get slightly more stiff, but hardly noticeable after a while.
Are these the ones you are planning to use fordtrucknut?
Heavy Duty Front and Rear Coil Springs for Dodge Ram 1500 ? 5500 and D250/350 Pickups
dpown is offline
post #5 of 7 Old 08-19-2014, 08:40 AM
sbluke55's Avatar
Quoted: 527 Post(s)
Garage
You will also need an adjustable track bar
01 f-250, Standard
Rev tech 4" lift,37" military wrangler Mt tires
KC diy 66, Full force 160/100 and custom tunes from PHP
Banks inner cooler and full 4" exhaust, Diy S&B intake
Diy quad feed, Hydra, Isspro boost, pyro, and fuel pressure
3/0 battery cables with military style terminals
sbluke55 is offline
post #6 of 7 Old 09-08-2014, 01:00 PM
Bump
Have you tried out the kit? Any Updates?
dpown is offline
post #7 of 7 Old 10-30-2014, 06:39 PM Thread Starter
update!!!
I decided NOT to lift/level the truck, I decided to go another route and leave it stock, did find out the truck had the taller F350 blocks in in the rear.
I decided to go with 19.5 tires and wheels, after blowing through a new set of tires in less than 15k miles I needed something with more wear life.
cool front bumper.
19?? F?50
1985 3/4ton frame
1995 body,
Torque Monster
