Fuel pressure sending unit loose - Ford Powerstroke Diesel Forum
post #1 of 1 Old 01-13-2014, 06:50 PM Thread Starter
Quoted: 8 Post(s)
I installed the fuel pressure sending unit, that came with my gauge, yesterday and it seemed really loose. I put in in the test port. I also wasn't comfortable with the o ring that came with it. I swapped the O ring for the one that came off the test port plug I removed as well as added some Teflon tape to the threads. I filled the housing back up, but I haven't fired the truck up yet. Has anyone else had this issue, how did you fix it?
2005 Excursion Lariat 4x4
Mishimoto coolant filter, RCD EGR delete, '03 turbo w/ single plane billet compressor wheel, Edge CTS w/ EGT probe, 5" Rough County suspension, Hellwig 32mm sway bar, 35x12.50 Toyo M/T, 20x12 Fuel Renegade D263 wheels
Originally Posted by F450Harley View Post
I really believe these trucks have adaptive behaviors to your driving habits. Your truck reflects you.
If you think your truck might let you down…………..it WILL.
6literdiesel is offline
