LED fog light question - Ford Powerstroke Diesel Forum
post #1 of 11 Old 12-31-2013, 09:10 AM Thread Starter
HP MACHINE's Avatar
Quoted: 165 Post(s)
Question LED fog light question
I recently purchased a 14" dual row led light bar to replace my existing
fog lights on my 04' . The wiring that comes out of the light bar is huge
compared to the truck wiring ( harness ) . I'm wondering if the stock
pos and neg wires , stock switch ( pull out headlight ) will supply enough
current ? I know little about led lights - the unit says 72watt and I'm
assuming the stock lights were 55 watt ?
Any input would be nice Thank you
HP MACHINE is offline
post #2 of 11 Old 01-01-2014, 06:28 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1865 Post(s)
Feedback Score: 4 reviews
You'd probably be ok, even with it being a 72 watt system the actual amperage is going to be pretty low. I just went through this on mine, but the lights I added weren't LEDs so I had to upgrade the wiring and make my own harness.
Also, there actually is a fog light relay so the current doesn't flow through the switch. It's one of the non-serviceable relays and is part of the central junction box
FWIW, the calculator I use shows 12 volts running 72 watts will draw 6 amps.....that's less than your pair of stockers.
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, KC S2R Ball Bearing Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 11 Old 01-01-2014, 03:09 PM
N.S.D.Q.
HeavyAssault's Avatar
Quoted: 158 Post(s)
Feedback Score: 3 reviews
A harness and relay would be a good upgrade. Watts and amps need to be checked.
Officially The Biggest Midget In The Game
(In support of Zmann's request)
HeavyAssault is offline
post #4 of 11 Old 01-01-2014, 11:31 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
72 watts should be no problem!
The stock foglight bulbs are only around 27 watts each, but me and many others run the 9006 bulbs in our foglights which are 60 watts each with no problems.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Bulletproof EGR cooler, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
post #5 of 11 Old 01-02-2014, 06:34 AM Thread Starter
HP MACHINE's Avatar
Quoted: 165 Post(s)
Thanks for the input guys .
post #6 of 11 Old 01-08-2014, 07:17 PM
I win....
cRaZy8's Avatar
Quoted: 48 Post(s)
Garage
Check the recommended fused amperage for the new light bar.
Compare that to the OEM fog light fuse amps.
Thats probably your safest bet.
Watts dont burn up wires, amperage does.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
post #7 of 11 Old 01-12-2014, 03:23 PM
BBWhiteDiesel's Avatar
Are y'all just taking out the 10amp fog light fuse in the fuse box and replacing it with a higher rated fuse or what?
Mine keeps on getting blown
07 F-250 6.0 KR
Sct/Custom, cs insight, Atlas 40, MTW stg 1, Ex center console, EGR misplaced,
Afe pro7, strait 4", 3.5" lift, Fog led bar, Zoodad, High idle,
DDM heads, Coolant Filter, BS, CCV
BBWhiteDiesel is offline
post #8 of 11 Old 01-12-2014, 03:45 PM
If you're blowing fuses it might be time to upgrade your wiring....the lights are pulling too much power (or have a short somewhere) and that's killing your fuses. If you do go bigger, don't go bigger than a 15amp or you'll be in danger of melting your wiring.
post #9 of 11 Old 01-12-2014, 04:01 PM
Alright thank you. Its a 20in bar so I might just go ahead and hook it up to an up fitter switch.
07 F-250 6.0 KR
post #10 of 11 Old 01-12-2014, 06:19 PM
7.3pwrstrke's Avatar
Just run a relay, I've done a 20" light bar in my fog light spot on my last 2 trucks and never had a problem with the relay. I found the wire that turned the fogs on and used it as my relay turn on wire. Works great!
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
