Looking to lift with new wheels/tires - Ford Powerstroke Diesel Forum
post #1 of 7 Old 12-24-2013, 11:42 AM Thread Starter
Hey everyone, new to to forums. So right now I have a 2005 f350 crew cab long bed 4x4. What I'm looking to do is a 4.5-5.5" lift. I've been doing some reading, and I've noticed tire running being a problem. My main question would be with a 5.5" lift, what size wheels and tires could I fit underneath it without problem? Also, would I need to buy wheels with back spacing and/or offset? Thanks in advance!
Austin
2005 f350 6.0L crew cab long box, banks ram air intake, cat removed
Austin.bridges is offline
post #2 of 7 Old 12-24-2013, 08:32 PM
Maxxforce365's Avatar
Quoted: 14 Post(s)
With coil springs I'm sure you could run 37's with minor trimming. That Look would be badass.
Instagram@platinum_forces
2015 Platinum F350 CCLB[/B]
EPA Delete Tuned by PIP
Fabtech 12" 4 Link Airdog II
04.5 F350 CCLB 4/04-7/25/15
MTW S2 Warren 175/30s Tuned by Gearhead
ARPs with OEM gaskets
Sinister Regulated Return AirDog II Beans sump
2012 Door Panels Fully Functional
Warn 12k winch
Fab Fours Front and Rear bumpers
Maxxforce365 is offline
post #3 of 7 Old 12-24-2013, 08:53 PM
Chilliboy93's Avatar
I'm running leaf springs with a leveling kit and I have 35s and they don't rub so with coil springs and that lift you should be able to fit 37s no problem but might have a little fender rubbing if your tire width is more then 12.5
Chilliboy93 is offline
post #4 of 7 Old 12-25-2013, 08:13 AM Thread Starter
Thanks. As far as wheels go, would I need to look into getting some with back spacing or offset?
post #5 of 7 Old 12-30-2013, 01:13 AM
I'm no wheel expert so don't take everything I say to heart but mine are offset and clear but if I picture it correctly it would be better for you too have a 0 or positive offset rather then a negative since you don't have leaf springs to worry about hitting.. Maybe some other guys will chime in on it and give you a little bit better information
Edit: the reason I say that about the offset is because a negative would push your tires out farther and risk rubbing on the wheel wells
post #6 of 7 Old 01-01-2014, 09:38 AM
On my 06 I run a 6" lift with a 20x12 on 35x12.5's and no rubbing.
JIMS SVT is offline
post #7 of 7 Old 01-08-2014, 08:13 PM
I win....
cRaZy8's Avatar
Quoted: 46 Post(s)
Garage
I personally think a leveled truck (2" front, F350 blocks in rear) with 35's looks the best.
No trimming, fills the wheel wells, gives it a great stance, and you dont sacrifice the huge mileage dump from the sky high lift exposing you undercarriage.
S362 68/.91
Irate SS T4
Holders 175/30
BPD FICM
BPD Cooler
BPD WP
ARP
Yukon Locker
4.30's
ODP St3 Manifold
NL CAI
Rudy's Intake elbow
PSP Coolant Tank
Mishimoto Rad. & IC pipes
EGR Del.
Edge CTS2
SCT X3
FICM Tune
Jugger Pump w/DIY RR
Fuel PSI Gauge
35x18's
Bilstein 2.5"
Trac. Bars
DC Power
Powerstops
USCG 50GT MMC
Yamaha Outboard Master Tech
cRaZy8 is offline
