Hooking up Inverter - Ford Powerstroke Diesel Forum
post #1 of 3 Old 12-09-2013, 08:07 PM Thread Starter
farmtruckman's Avatar
Hooking up Inverter
I am planning on installing an inverter in my 2006 F350 with 6.0. My question is to what battery should I hook up to. I have the dual battery option with two Optima Red Tops in the factory locations. Does it matter which battery that I hook up to?
FTM
farmtruckman is offline
post #2 of 3 Old 12-10-2013, 08:29 PM
Quoted: 50 Post(s)
FTM
All Ford Super Duty's with diesels have dual batts. Both are connected together, but the passenger side battery is closest to the alternator so suggest connecting to that one. Also suggest upgrading your alt, as these trucks are underpowered in terms of electrical.
2016 F350 CCSB 4x4 6.7 FX4 Lariat Ultimate
Ruby Red with Black Leather
3.55s, OEM 20s, Locking Rear Diff
Icon 2.5 CDC Shocks
TufTrucks 2.5" 7,500 lb coils
Carli Track Bar
Carli High Mount Stabilizer
Titan 50g Midship Tank
295/65/20 Nitto Ridge Grapplers
Previous:
2006 F250 CCSB 4x4 6.0 FX4 Lariat Ultimate
All the BPD goodies
skanj0 is offline
post #3 of 3 Old 12-10-2013, 08:33 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
I went with the drivers side because its closer to were I could easily run the wire through the firewall with the factory provided hole in the fire wall. And it was shorter distance to run the wires to the invertor.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
