Cab clearance light question ? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 11-26-2013, 01:08 PM Thread Starter
HP MACHINE's Avatar
Quoted: 152 Post(s)
Question Cab clearance light question ?
Does anybody know the thickness of the roof on a F250 Super Duty ( 04').
I'm trying to come up with a way to mount aftermarket cab lights and
before I start drilling I'd like to know what I'm into .
Thanks guys
HP MACHINE is offline
post #2 of 12 Old 11-26-2013, 03:07 PM
mikemike0409's Avatar
The cab roof is not very thick at all its no problem to drill into. I did it when i added two more cab lights.
mikemike0409 is offline
post #3 of 12 Old 11-27-2013, 06:38 AM Thread Starter
HP MACHINE's Avatar
Quoted: 152 Post(s)
What did you use for fasteners ? SS screws ?
post #4 of 12 Old 11-30-2013, 09:58 AM
Jeremy@TDA's Avatar
Quoted: 118 Post(s)
I mounted my recon cab lights with #6 bolts, washers and nuts. The ones that come with the recon lights are like sheet metal screws and tend to strip out in the thin sheet metal.
Jeremy
Owner- The Diesel Authority
Instagram- @thedieselauthority
2017 event info!!!!
2015 6.7 Platinum
Lots of NL stuff
H&S 369SXE
Spartan tuning
2006 Shorty in progress
Lots of fuel, turba and NL stuff
Jeremy@TDA is offline
post #5 of 12 Old 12-01-2013, 07:11 AM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1785 Post(s)
Feedback Score: 4 reviews
most factory lights are screwed in with extruded u-nuts if that's helpful
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #6 of 12 Old 12-01-2013, 07:17 AM
ZMANN's Avatar
Quoted: 1673 Post(s)
my recons came with chit hardware they actualy came with screws that were meant to go into nylon push lock inserts ( the kind OEM would have say on a licsence plate in a square hole ) but the f tards didn't give you the inserts and who would mess with them anyway ?
you don't need SS screws because they should never see water but Jeremy called it I did use sheet metal screws but the thin gauge sheet metal is better suited for the nut and bolt
We Miss you Ronnie
ZMANN is offline
post #7 of 12 Old 12-05-2013, 04:26 AM Thread Starter
HP MACHINE's Avatar
Quoted: 152 Post(s)
Thanks for the info guys , need to to make a really intelligent decision here because
you only get one shot . Don't need to @#$#@# up here !
post #8 of 12 Old 12-05-2013, 04:50 AM
measure, measure measure, then measure again.....then take the drill to her and you'll be ok.
post #9 of 12 Old 12-09-2013, 05:36 PM
BBsBlueOval's Avatar
Where can I find the measurement for the cab lights, just got mine in the mail and I'm itching to get them on
Livin the Lake Life
BBsBlueOval is offline
post #10 of 12 Old 12-09-2013, 06:18 PM
Mod Newbie
dhanna6powerstroke's Avatar
Quoted: 20 Post(s)
My factory lights had studs built into them and used regular nuts to pull them down snug to the cab
dhanna6powerstroke is offline
