LED Clearance Lights not bright - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-16-2013, 04:04 PM Thread Starter
JohnO38's Avatar
Quoted: 6 Post(s)
Garage
Has anyone upgraded to Retro Solutions T10 LED's in the cab clearance lights? I am curious if I ordered the wrong bulb because they are about half as bright as a stock bulb. I went with the amber light and I am running the factory amber lenses. Should I go with clear lenses?
2009 F350 Lariat
5" Straight Pipe
AFE Momentum
SCT X4
PIP 150
Edge CTS
2004 King Ranch
ARP Studs
5"straight pipe
BPD EGR
ISSPRO PILLAR
X-Code
JohnO38 is offline
post #2 of 7 Old 12-05-2013, 05:41 PM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Yes these are recon lenses with white LEDs [ATTACH]209274
EDIT: My lenses are smoked and the bulbs are amber.
sent from my Samsung S4
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #3 of 7 Old 12-05-2013, 06:03 PM Thread Starter
JohnO38's Avatar
Quoted: 6 Post(s)
Garage
Looks good!! I am getting ready to order clear lenses.. Overall I am very impressed with the LED's. Converted all exterior lights.
2009 F350 Lariat
5" Straight Pipe
AFE Momentum
SCT X4
PIP 150
Edge CTS
2004 King Ranch
ARP Studs
5"straight pipe
BPD EGR
ISSPRO PILLAR
X-Code
JohnO38 is offline
post #4 of 7 Old 12-05-2013, 06:29 PM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Clear recon lenses with OEM bases and LED's! This will be my next mod!
Sent from AutoGuide.com App
2000-7.3L is offline
post #5 of 7 Old 12-06-2013, 09:20 AM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
I edited my last post. I was multi tasking (talking with the wife)....
Shawn
Qholic is offline
post #6 of 7 Old 12-06-2013, 11:17 AM
Suck, Squish, Bang, Blow!
dfuzz78's Avatar
I did this a while back and they are not as bright as a standard bulbs because there is only one small LED facing forward.
I took them out and just run the standard bulbs now.
Denis "Lt. Sled"
2006 F-350 Crew Cab Long Bed Dark Shadow Gray
462hp / 927ft-lbs Corrected
ARP Head Studs, NUC Motorsports Oil Bypass, CFM+ Intake Elbow, Wicked Wheel 2
Bullet Proof Diesel FICM w/Atlas 40, SCT SF3 w/SPD by TSD! Grover Fire Truck Horns
Cab Light Mod, Blue Spring Mod, Zoodad Mod, High Idle Mod, Lost EGR Mod
dfuzz78 is offline
post #7 of 7 Old 12-06-2013, 09:48 PM
Semper Fi
TClev's Avatar
Quoted: 2 Post(s)
Garage
Check out the link in my signature for my LED conversion write up. I posted plenty of pictures and information, hopefully it can help out.
Tony Clevinger
06 F250 6.0L Auto Trans - 124,000 mi
Lariat FX4 CCSB
Toyo Open Country 275/65R20
Bilstein 5100s
Edge Evo CTS
Deleted by Scheid Diesel - Lafayette, IN
Bulletproofed by Reckless Diesel - Dallas, TX
CAT EC-1
Rotella T6
XDP Coolant Filtration
Blue Spring
Turbo Oil Feed/Drain Update
Injen Power-Flow Intake
MBRP 5" Stainless TB
Riff Raff Hot Side CAC Boots
Upfitter SEIC
TClev is offline
