4.5'' to 6'' - Ford Powerstroke Diesel Forum
post #1 of 6 Old 11-14-2013, 03:45 PM Thread Starter
STRKTHS73's Avatar
Send a message via AIM to STRKTHS73
4.5'' to 6''
heres a question for all you suspension guys, right now i have a 4.5'' rough country lift in my 06 f-350 i want to go to 6'' lift anyone know what i need to get to make it happen besides buying a whole new system?
06 F-350
4" turbo back silverline exhaust
KMC XD series spy wheels
35" toyo m/ts, 5% window tints
4.5 rough country lift
triple pillar egt, boost, and trans temp
edge cts insight
CAT coolant swap at 30k
Sinister Coolant Filter
SCT X3 with custom tunes by vivian at QT
STRKTHS73 is offline
post #2 of 6 Old 11-14-2013, 03:54 PM
c dog's Avatar
What about if you run a 1.5"-2" spacer/leveling kit under your front coil springs and a larger block in the rear leaf springs? Just a thought
Sent from AutoGuide.com App
c dog is offline
post #3 of 6 Old 11-14-2013, 03:58 PM Thread Starter
STRKTHS73's Avatar
thats what i was thinking about doing didnt know if anyone ran into problems with that im sure id need a new pitman arm maybe sway bar end links or relocation brackts and i already have the massive block in the back from the original lift so idk what else would pick the back up another 2 inches haha
06 F-350
edge cts insight
post #4 of 6 Old 11-18-2013, 05:26 PM
305f250's Avatar
I have a buddy who has a massive lift.. I think he is running a 10" block.
305f250 is offline
post #5 of 6 Old 11-18-2013, 05:35 PM
Look at the drop arm brackets, I believe they might have another hole to be used as a 6 inch. I think they use the same brackets on 4.5 and 6 inch. I'd say a 1.5 inch spacer wouldn't make any difference.
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #6 of 6 Old 11-18-2013, 06:57 PM
Mo Diesel sir!
sleepy steve's Avatar
Quoted: 51 Post(s)
you could always do an ADD A LEAF in the rear leaf springs or get some lift shackles for the rear and do the spacer up front
2003 F350 6.0 CCSB 4x4
3.5" lift with 17" MT Classic II 35x12.50/17Terra Grappler G2
4" MBRP turbo back cat delete, ARP studs,
SCT Tunes from PHP & WPE, Bullet Proof EGR cooler,
HID heads and fogs, 08+ tailgate/tails/mirrors,
LED bars and pods, FICM from Ed, Blue Spring
DC Power 270 alternator, Mishimoto intake elbow,
Mishimoto Coolant Filter, Scan Gauge II,
A-pillar gauges (Boost, EGT, Fuel pres.),
Air Compressor for Sh**s and giggles
for life!
sleepy steve is offline
