Updated Towing Mirrors - Ford Powerstroke Diesel Forum
post #1 of 7 Old 11-12-2013, 10:08 AM Thread Starter
I just bought an 04 F-350 which has power towing mirrors on it without heat or turn signals. I would like to upgrade them to mirrors with these options, but I don't want to go through the hassle of doing all the wiring myself. I've read many forums and tried doing research, but either I can't find the answer to my question or I've seen different answers. I've read where people say that the trucks are wired for the heat and turn signal options already, so all you need to do is plug in the new mirrors that have these options on them. I've also read where if the truck doesn't have these options, the new mirrors will not work and you have to run your own wires for heat and turn signals. My question is whether or not the trucks all come wired from the factory with the same wiring harness, or is the heat and turn signal option missing from my truck?
strokerace6 is offline
post #2 of 7 Old 11-24-2013, 10:29 PM
FORD4LIFE
powerstrokeculver's Avatar
Quoted: 2 Post(s)
I see no one has posted anything so ill be the first to say it. Try calling Ford. Or hell even BPD. Those guy know just about everything there is to know about these trucks. I almost want to say the 03-04's had a button for the heated option. I think you can solve this with a phone call bro.
Work Horse
2006 F250 FX4
6'' Lift Donahoe Racing
Toyo ATII's 35x12.5R18 on Moto Metel Black
BPD Engine Oil Cooler
BPD FICM 53V
K&N CAI
4" Straight Pipe
XDP Coolant Filter Kit
Blue Spring mod
SCT Tuned by DP-Tuning
ARP Head Studs
Nothing But AMSOIL!
To-Do list:
FICM Tuning By PHP
155cc or 175cc Injectors
Stage 1 or 2 Turbo
BPD Water Pump
powerstrokeculver is offline
post #3 of 7 Old 11-25-2013, 10:16 PM
7.3pwrstrke's Avatar
Go to the 7.3 section, there's a lot more info on this considering your truck is actually the same body style.
08-10 Tow mirror install
2003 F250 Lariat 7.3 160k
3" leveling kit, 22x14 Moto Metal 962, 33x12.50 Toyo MT, 2" wheel spacers
Harley heads, 08+ mirrors, 08+ taillights, LED switchbacks, HIDs, 20" LED light bar
DP Tuner, 4" turbo back (dumped before rear passenger tire), 6637 intake, Glowshift gauges
7.3pwrstrke is offline
post #4 of 7 Old 12-11-2013, 10:35 AM
USAFBowman's Avatar
I have an 04 with heated mirrors. There is no said button to push to turn the heater on. All the wires should (should) be there so all you have to do is plug a new one in.
USAFBowman is offline
post #5 of 7 Old 12-11-2013, 10:49 AM Thread Starter
I was wondering about that. I talked to a ford parts guy just this week and asked him this question, but I don't know whether he really knows or if he was just giving me his opinion. He told me that the heated mirrors run off of separate relays and he thinks that the mirrors without the heat and running light option won't have the correct wiring harness to just plug and play with mirrors that do.
post #6 of 7 Old 12-11-2013, 04:55 PM
USAFBowman's Avatar
When I get time tomorrow I will take my door panel off and take a picture of mine so you can compare the wires in yours if that will help you out.
post #7 of 7 Old 12-11-2013, 05:23 PM Thread Starter
That would be awesome! I can't seem to find an answer anywhere else so I appreciate it a lot!
2004 Ford F350 Lariat CCSB 6.0L
-ARP Head Studs
-Sinister Diesel EGR Delete & Oil Cooler
-Coolant Filter
-SCT Innovative Diesel Custom Tunes
-Edge Insight CTS Monitor
-Volant Cold Air Intake
