rear sliding window weather strip - Ford Powerstroke Diesel Forum
post #1 of 2 Old 11-10-2013, 03:57 PM Thread Starter
mustangmike6996's Avatar
My weather strip has come unglued which seems like a common problem on the center sliding rear window. I have searched the forum and found limited info. Im looking for a part number or possibly a suggestion as to C-channel rubber that can be used.
Im 99% sure I need to pull the sliding window to *properly* reglue the window in the weather stripping. With that being said, Im pretty sure that the old weather stripping is going to tear the rest of the way if I try to reuse it.
any help is greatly appreciated.
mustangmike6996 is offline
post #2 of 2 Old 11-30-2013, 08:22 AM
Id love to know how you went about fixing it. Mine is starting to peal back and its stopping the window from sliding all the way closed.
2003 6.0 F250 "Onyx"
4inch lift
35'' Falken Wildpeak AT
SCT FX3 Performance tune
Edge Insight CTS
Edge EGT probe & Fuel Pressure sensor
Blue spring upgrade
Bulletproof Diesel EGR Cooler
Updated Motorcraft Oil Cooler
Sinister Diesel Coolant Filter
Rotella ELC
MBRP 4'' Turbo Back SS Straight pipe
Alpine head unit
Rockford Fosgate speakers
Still need to stud it....
aeby07 is offline
