Tailgate and grill - Ford Powerstroke Diesel Forum
post #1 of 8 Old 11-07-2013, 06:16 AM Thread Starter
Send a message via Skype™ to 2004strokerJeremy
Tailgate and grill
I would like to put the grill off of the 06 F250 and the tailgate from the model that has the slide out step? Will the grill fit in just like the factory one I already have and will the tailgate from the newer models with the step fit?
Sent from AutoGuide.com App
2004strokerJeremy is offline
post #2 of 8 Old 11-07-2013, 07:38 AM
depends on what year your truck is. 05-07 have different grills than 03-04. Some modifications will need to be made if you have an 03-04. As for the tail gate it will fit. you just need the drivers side hinge
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #3 of 8 Old 11-07-2013, 09:07 AM Thread Starter
I want the flat chrome style so if it's just drilling a few new holes then I'll go for it. And the tailgate will just need the different hinges. Height is the same and it'll be flush with the taillights?
post #4 of 8 Old 11-07-2013, 11:29 AM
the 03-04 grills are different than the 05-07 grills. there is more to it than just drilling some holes. Yes the tailgate will sit as it should
KCCO
Paul Devereux
DEVERO2 is offline
post #5 of 8 Old 11-07-2013, 11:35 AM
DIMBLEWAMBIE's Avatar
heres what your after for the grill
2005 2006 F250 F350 Grille Superduty Grill Conversion | eBay
you can buy a factory ford one and trim the bottom yourself and save a few bucks.
DIMBLEWAMBIE is offline
post #6 of 8 Old 11-07-2013, 12:02 PM
codyryan07's Avatar
What year is your truck? That'll help us all in being able to assist you on the grill question..
When you get the chance, fill out your sig.. it'll help everyone know more about your rig, and easier to help out.
Cody Ryan
03 f250 ccsb fx4 7.3
4" RC lift
35x12.50 federals on 20x12 rockstars
6637 intake, straight pipe
full RR w/ fuel bowl delete.
rebuild coming soon
codyryan07 is offline
post #7 of 8 Old 11-07-2013, 12:06 PM Thread Starter
2004. Date stamp in the door is November of 03
post #8 of 8 Old 11-07-2013, 12:14 PM
codyryan07's Avatar
You have the older grille, so there's 2 ways to get the 05-07 grille.. either using the one linked above that's already cut, or buying used and trimming yourself.
Cody Ryan
4" RC lift
rebuild coming soon
