Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
  #11 (permalink)
Old 07-13-2008, 01:59 PM
ridetillurdead26 ridetillurdead26 is offline
Okay thanks guys. With the 37's will i eventually need to regear? Right now I'm stock gears and ID tuned SCT
Edit: post more pics!
  #12 (permalink)
Old 07-13-2008, 02:56 PM
DCSpecial DCSpecial is offline
Yes, I would regear with 37s.
  #13 (permalink)
Old 07-13-2008, 03:04 PM
fordmugg fordmugg is offline
im running 35's on a 6 inch lift and as soon as they wear out im going 37's and a re gear .....im thinking 430 gears
  #14 (permalink)
Old 07-13-2008, 03:27 PM
outrage outrage is offline
Here is my 2004 F-250 with 6.5" pro comp lift with 35's (325x60x20). The rims are 20x9
  #15 (permalink)
Old 07-13-2008, 03:31 PM
This should be a larger pic to see the fit of 35's better. Hope it works
  #16 (permalink)
Old 07-13-2008, 03:32 PM
DunesRunner08 DunesRunner08 is offline
If this is a boulevard bruiser...the 37's all the way.....if you are going to offroad go with the 35's....the reasoning is that the 37's will hit and rub and damage and get damaged when the suspension is flexing offroad
  #17 (permalink)
Old 07-13-2008, 03:37 PM
Nally7.3Powerstroke Nally7.3Powerstroke is offline
Stroke This
Definitely go with the 37's, although you might have to do a little cutting, it would be well worth it.
  #18 (permalink)
Old 07-13-2008, 03:39 PM
TANK'S 250 TANK'S 250 is offline
Powerstroke.org - Sponsor
if you do a little more cutting...put 41's on...
  #19 (permalink)
Old 07-13-2008, 04:00 PM
Tank, You are obsessed with your 41's. And I do plan on doing some off roading as I already have in the short month that I've owned it. So you think 37's would mess things up?
  #20 (permalink)
Old 07-13-2008, 04:05 PM
LOL...
I'm obsessed with small lifts and huge tires...
37"s on a 6"?....your gonna rub a little, if you drive aggressively
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
