Will 20" rims off 2006 F-250 fit 2004 F-350? - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-14-2013, 03:54 PM Thread Starter
Will 20" rims off of a 2006 F-250 fit my 2004 F-350? I found some on craigslist but wasn't sure if they will fit. Thank you.
Will
2004 F-350 Lariat Crew Cab FX4, Dark Grey, T3 Front and Rear replacement bumpers, Fumoto valve, Diamond plate running boards, Zoodad mod, Dieselsite coolant filter w/ ELC, Blue Spring Mod, LED cab lights, Edge Insight CS, SCT SF3, PHP FICM/ECM rollback, Sinister EGR Delete, 6.4 Banjo Bolts, ARP head Studs, Zone Offroad Leveling Kit, CCV Mod, Straight Exhaust, S&B intake, Atlas 40, 295/75R16 BFG,
fishmanwill is offline
post #2 of 3 Old 10-15-2013, 01:45 PM
yes they will
2006 F250 CCSB LARIAT FX4
studs, oil cooler, egr delete, 4"exhaust SCT, Wicked Wheel
streetdemon70 is offline
post #3 of 3 Old 10-15-2013, 01:48 PM
Don't you worry about it
strokinpower's Avatar
Quoted: 277 Post(s)
They will bolt up however you will need to get some spacers because the never trucks axles are wider therefor the offset is different. These wheels will set further in on your truck than an 05-up so they may rub on your springs.
2014 Platipus
AP Intake
Spartan EZLYNK
4" Dual Exhaust
4" BDS with Fox shocks and PMF stage 2 traction blocks
strokinpower is offline
