grill/brush guard with 2 inch receiver - Ford Powerstroke Diesel Forum
post #1 of 3 Old 10-12-2013, 08:23 PM Thread Starter
Hey guys, I have been thinking about putting a brush guard on the front of my truck. 07 KR. I kinda like the Warn trans4mer, as you can buy the 2 inch receiver section, a winch cradle, or a step bar to go in the lower section of the guard itself. I personally want to do the 2 inch receiver as that setup provides more options for hookups for pulling (and you can stand on it to get under the hood), or in my case a removable winch cradle so I can use it up front or out back, and I can store it in my LOCKED toolbox when not needed.
Does anyone have any experience with these, how do they hold up under load? I think they are only rated at 12000 lbs and I already have a 16500lb winch, I dont want to buy a whole bumper assembly like ranch hand or other similar styles.
Any suggestions or comments are appreciated.
Thanks
cjw13cjw is offline
post #2 of 3 Old 10-28-2013, 10:38 AM
Fummins90's Avatar
Seeing as how it bolts to the tow hooks, which bolt to the frame, id say its worthy of holding up to as least the weight of the truck.
-Jacob
PowerHungryPerformance --
Comments or opinions expressed by me do not necessarily represent the views of PHP, its management, nor its employees. PHP is not responsible for, and disclaims any and all liability for the content of comments written by me.
Fummins90 is offline
post #3 of 3 Old 02-22-2014, 06:52 AM
dxusmc's Avatar
I did this on my old dakota for a winch setup..I'll Have to search for the pictures.. But I ended up getting her rutted up pretty good and winched to a tree. Ended up pulling the grille guard away a little bit. But I know my SD's grille guard is much better designed, so I'm not sure.
ID:	246833   Click image for larger version
ID:	246841   Click image for larger version
2004 F250 XLT 6" lift, 37" tires, zoodad, T6,
edge cs, k&n, revx, warn lockers, rhino bars
future: coolant filter, headstuds, bluespring, 4" turboback, tires..dam these tires
Marines 2004-2009
Army 2009-2013
dxusmc is offline
