Cab light install - Ford Powerstroke Diesel Forum
post #1 of 7 Old 09-21-2013, 09:26 AM Thread Starter
Quoted: 390 Post(s)
Cab light install
Hey guys.
In the middle of doing a cab light install, went with Recon. Seems like a bad idea so far. The wiring harness they provided comes with a ground and a single pig tail. I'm sure I can ground it anywhere, but I can't figure out where to attach/splice-in the pig tail. Anyone got insight? I looked at Marty's thread and I can't find a similar plug.
As an aside, it looks like Recon poached their instructions off the internet, and included nothing about how to wire this thing in. Doesn't help their tech support is only available during regular business hours, which is when 90% of DIY types are off making a living. Tech support fail on Recon's part.
Thanks for your time.
2005 F-350 ext. cab long box, FX4
EDGE Insite CTS w/ fuel pres, EGT, and rear diff temp
Blue Spring
BCP High Idle Mod
DS Bypass Coolant Filter
Rotella ELC
Rotella T6 5w-40 Synthetic
EGR Cooler Delete
Bulletproof Oil Cooler, Oil Filter, & Amsoil Bypass Oil Filter
268 000km/167 500 miles as of Jan. 1 2015.
Canadian Mind is offline
post #2 of 7 Old 09-21-2013, 12:02 PM
ZMANN's Avatar
Quoted: 1356 Post(s)
they are chitty
yes the ground is any ground what are you needing the power connection ?
We Miss you Ronnie
ZMANN is online now
post #3 of 7 Old 09-21-2013, 12:03 PM
ZMANN's Avatar
Mounting Recon cab lights
http://www.emotoman.com/f250/lights/f250lights.htm
secure the connectors at each cab light if they are still using that mismatched junk like in the pictures
nothing like getting all done and having some not work
We Miss you Ronnie
ZMANN is online now
post #4 of 7 Old 09-21-2013, 12:11 PM
ZMANN's Avatar
they did jack Martys pages LOL
http://www.gorecon.com/download_file...ownload_key=53
We Miss you Ronnie
ZMANN is online now
post #5 of 7 Old 09-21-2013, 04:35 PM Thread Starter
Quoted: 390 Post(s)
Found solution, spliced the positive to the #12 behind the light selector switch. I'll just attach the negative wherever.
Blue Spring
BCP High Idle Mod
Rotella ELC
EGR Cooler Delete
post #6 of 7 Old 09-21-2013, 04:41 PM
ZMANN's Avatar
ahh I did mine in the pass side sill plate
i didn't know what you were after or I would have elaborated
We Miss you Ronnie
ZMANN is online now
post #7 of 7 Old 09-22-2013, 02:28 PM Thread Starter
Quoted: 390 Post(s)
Whatever, I got it up and running.
I wouldn't reccomend their complete kit, the instructions and parts do not jive at all. also, their plastic base plate is very prone to stripping where the screw for holding the cap goes with minimal force.
Blue Spring
BCP High Idle Mod
Rotella ELC
EGR Cooler Delete
