2004 f350 lift options - Ford Powerstroke Diesel Forum
post #1 of 2 Old 09-12-2013, 05:53 PM Thread Starter
Looking for 4-6" lift options for a 2004 f350.
Any suggestions?
Big Draggo is offline
post #2 of 2 Old 09-12-2013, 07:09 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
There are a few of options for the front and rear.
Front: hangers(added to the top of leafs to give more space between the leaf and the cab) mini blocks( a set of blocks that are set below the leaf spring) and a brand new set of leafs which is what I would suggest. There are a few brands out there rough country, tuff country etc etc but if you want it to ride great when you are done I would highly suggest using some lifted leaf springs made by a company called deaver springs.
Rear: taller blocks ( I would recommend the ones made by precision metal fabrication because their design supports the u-bolts) Ford Fabricated Lift Blocks
or you could buy a new set of lifted leafs. Another thing to consider while you have the u-bolts out anyway is adding traction bars to reduce axle wrap.
I only know all of this because I too was looking to install a lift(2") on my 04 F350 but I decided that I would rather put the money toward bulletproofing.
hope this helps
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
