DIY RBP grille? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 09-09-2013, 09:11 AM Thread Starter
Justin39339's Avatar
DIY RBP grille?
Hello, I know this has been probably asked a lot. I have tried searching the forums and didn't really find much, but does anyone know how to make there 05-07 grille look like those rbp grilles. I want to paint it and cut it this weekend and run to hardware store to get the mesh and bolts and stuff just not really sure what people are using to cut there grilles and and where exactly. from looking at some pictures it looks like people are cutting out the center before the 2 parallel bars.. any help, steps, and or advice would be great. Thank you
2006 FX4 Crew cab F250
Bone stock right now
Justin39339 is offline
post #2 of 8 Old 09-10-2013, 02:21 PM
mxrider777's Avatar
I did mine about a year ago, used die grinder and a cut off wheel, just be careful cutting the chrome chips easily
2003 F250 CCSB 6.0l
12' lift
43" Michelin xls
sinister coolant filter
zerex elc coolant
edge insight
Egr Delete w/ coolant reroute
mxrider777 is offline
post #3 of 8 Old 09-26-2013, 05:24 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
Here is my write up on my DIY grille...
Write Up: DIY Custom Grille
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #4 of 8 Old 09-26-2013, 05:33 PM Thread Starter
Thanks Rollinearly99. Problem I am having is buying that expanded metal apparently it's hard stuff to find around me lol. I do love the way yours looks. Great job
post #5 of 8 Old 09-26-2013, 05:53 PM
Quoted: 8 Post(s)
Home Depot sells it in my town. You don't have a metal yard that sells ductile iron pipe, fitting, angle iron... Etc?
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 8 Old 09-26-2013, 05:55 PM
Quoted: 8 Post(s)
Crown Bolt, 24 in. x 3/4 in. x 24 in. Metal Plain Expanded Sheet, 45840 at The Home Depot - Tablet
This is smaller than what I used but you could put 1 1/2" wide metal strips across the center... Kinda like the RBP grilles.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #7 of 8 Old 09-27-2013, 06:55 AM Thread Starter
Awesome thanks man! I will go on my lunch break and look for that. Is 24" x 24" big enough to cover the grille?
post #8 of 8 Old 09-27-2013, 06:59 AM Thread Starter
Ok nvm, sorry disregard Just read your underlined sentence saying this was just a little bit smaller. I will still look to see if they have anything bigger
