315 / 75 / 16 with a leveling kit only? - Ford Powerstroke Diesel Forum
post #1 of 17 Old 08-27-2013, 06:45 PM Thread Starter
lawman349's Avatar
Will this work? Anyone have pics of this setup?
2003 F350 SRW CC 4x4 6.0L
Coolant Bypass Filter w/ Cat ELC
Amsoil Oil Bypass Filter
Hypertech MaxEnergy / Bully Dog Outlook
Cat and muffler DELETE!
Icon 2" leveling kit
Mickey Thompson MTZs
ARP Head Studs / New Ford OEM HGs
New heads
Sinister Diesel EGR Cooler
Blue Spring Upgrade
New HPOP STC connection
lawman349 is offline
post #2 of 17 Old 08-28-2013, 12:09 AM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
I don't believe so, unless you trim and get some weird back-spacing for you wheels. If you look at more 4 in lift kits they says "max tire size--35x12.5 or a 315x75r typically a 35in tire... i know on most 05 and up a leveling kit will allow 35s though.
most 35's and 315/75r16 measure 34.6 inches tall take a tape measure and see. also rubbing might be an issue. and my 8in lift is being removed so when i get it back with the 4in and 35's i'll send ya pic shouldn't be more then couple days.
currently-1999 F250 SBRB 4X4 7.3, 6.0 trans cooler, 08 mirrors, AIS Intake, Hydra, Level kit, 33s.
-2004 F350 CCLB 4x4: Sinister Race solutions kit, CAT ELC Edge CS, SCT SF3, PHP Ficm programmer, Procomp, Rough country, and Nitto goodies.
-2004 excursion, banks exhaust, 03 turbo, aem intake. 4in lift, 35in kumhos
-2006 f350 king ranch, aem intake, 10 in fabtech, 40in tires, sct tunes.
Interested in learning something new?
Justin,
2F071 USAF 2008-2014
JustinOOO9 is offline
post #3 of 17 Old 08-28-2013, 12:25 AM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
They will fit fine just rub the fender liner at full lock unless you zip tie it back depending on what year truck
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 17 Old 08-28-2013, 10:53 AM
USAFBowman's Avatar
This is correct. My truck is set up the same way, 315/75R16 on just a leveling kit. I rub on my leaf springs of course (2004) and it does rub on the plastic fender liner a little bit.
USAFBowman is offline
post #5 of 17 Old 08-28-2013, 12:58 PM Thread Starter
lawman349's Avatar
Sweet. Mine's a 03. Got any pics of your rig you can post up?
New heads
Blue Spring Upgrade
post #6 of 17 Old 08-28-2013, 04:16 PM
USAFBowman's Avatar
I will snap a pic and post it up tomorrow. I do not have any on hand right now and I am at work
post #7 of 17 Old 08-28-2013, 06:48 PM Thread Starter
lawman349's Avatar
Great! Thanks!
New heads
Blue Spring Upgrade
post #8 of 17 Old 08-29-2013, 07:53 AM
Quoted: 3 Post(s)
Feedback Score: 5 reviews
If you have V codes 35" will clear with a 3" hanger kit.
PM me if I can get you what's needed.
CT Performance, Inc. is offline
post #9 of 17 Old 09-16-2013, 05:10 PM
PyroTekRob's Avatar
Quoted: 295 Post(s)
Leveling Kit only, Tire size in Sig
2006 F250 Amarillo 4x4 CCLB - 210,xxx
SCT Livewire TS - Tunes from Vivian (Eco, Tow, Tow w/ JB, Looney)
DrawTite Flip Over Goose
Leveling Kit - Wildpeak AT3Ws 325/75R18
Sinister Diesel Coolant Filter
Garrett Powermax Turbo
DC Power Engineering 185amp Alt.
BPD Heavy Air Oil Cooler
BPD EGR
LED bulb upgrades.
Curt Class V - Air Lift Load Level 5k Ult - Wireless Compr
PyroTekRob is offline
post #10 of 17 Old 09-16-2013, 06:10 PM
JustinOOO9's Avatar
Quoted: 507 Post(s)
Garage
well my 04 with a 4in rough country bent a small corner of my drivers front fender on the rear going over big dip.... so i would get a 4 or 6in for 35's...
just happened the other day.
Justin,
