- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 6.0L Exterior Discussion Body and Accessories Talk |
Does anyone know of a custom grille cover made for Ford Superduty's? I've seen them on bigger rigs in the winter time. I have an '06 F250 6.0 PSD. I started wondering about some type of grille guard cover last year with my '05 PSD. Was wondering if it would help it warm up quicker and hold the temp better. Does anybody have any experience with this, or is it something I should avoid altogether? I would like to find something made from the same material that car bras are made from if possible. Would like a custom fit. I live in Iowa and the winters can get down right cold. If anybody has any information or opinions please drop a reply. Thanks in advance.
Kurt |
| Sponsored Links |
this is probably as close as yur gonna get, if you had something to cover the front grille like that black leather on the car bras it would over heat due to no air flow through the radiator. i guess you dont have a block heater? |
Yes, I have a block heater. I've never used it as the truck is garaged unless I'm working night shifts. I've got a 40 minute drive home in the morning, all highway. I've noticed when it gets really cold that the truck takes 10 minutes or so to blow good heat. Just thought that some sort of cover would help.
Check Cabelas, www.cabelas.com I saw they had some in there.
thanks!
Usually when it gets cold, if you plug your truck up, it helps a ton. You might want to try and keep a cord with ya this winter that you can plug up anywhere. In just a min or two you are blowing real hot air and you don't have to worry about anything messing up the front of your truck. Just a thought. Be cheaper too.
Diesels run so cool.....plus the fact that there is still air coming from under the truck......that those actually wont cause an overheat under COLD operating (less than 40 degrees) for most trucks under non loaded situations....
| Sponsored Links |
