Painting rockers and wheel wells with Herculiner - Ford Powerstroke Diesel Forum
post #1 of 14 Old 08-21-2013, 08:21 PM Thread Starter
Nifty2Fifty's Avatar
Hey everyone, I'm considering painting my rockers and wheel wells with Herculiner. I've done quite a bit of research into the matter, and I think I'm going to pull the trigger. I know its all in the prep work, but my only concern is, I've got some rust on my wheel wells, and the bottom of my doors are showing some rust as well. So I'm worried that it'll create an issue after I use the liner. If I sand the body down and sand away any visible rust, then neutralize it, I should be okay then correct?
My other question is then, whats the best product to go with to neutralize the rust then paint over with? I've heard some things about Ospho and others. Anyone had luck with any specific product? Thanks in advance for any input!
2006 Ford F-250 6.0L
XDP Coolant Filter System - Bluespring Upgrade
Bushwhacker Pocket Style fender flares, Herculiner down the rockers
MBRP 4" Turbo back Exhaust
Nifty2Fifty is offline
post #2 of 14 Old 08-30-2013, 05:07 AM
phantom-3k's Avatar
Quoted: 14 Post(s)
Garage
I am tackling the same thing with my truck. Rusted completely thru on my rear fenders, had to cut them out. The problem is, the rust is working its way from the inside out. You have to get inside and neutralize it. Out here there is a company that has a neutralizer that they spray on the inside of the vehicle, inside the doors, tailgates, fenders, rockers, and so forth.
I just cut out the rust on my fenders and sealed it. Going to spray and oil on the inside of the fenders for now. Bought some Bushwacker OE styler flares, and going to bed line (using the herculiner roll on) the bottom part of my truck including the fender flares. Then I am going to that company (Ziebart) getting a full rust inhibiter/undercoat and have them spray in all the openings with that neutralizer.
It's a lengthy and costly fix, BUT I HATE RUST!!! lol
Good luck with yours! Ill keep updating with my progress.
Dave Lenharr #213
Add me!
New Truck!
2011 F350 CCSB Lariat, 2.5 Levelling, 5in FloPro, DPF Delete, GearHead Tow | Street | Extreme Street | Race.
SOLD
2005 F350 CCSB 2.5 Levelled, 5in straight pipe, EGR Delete, SCT Custom Tuned by Vivian - Looney
phantom-3k is offline
post #3 of 14 Old 08-30-2013, 10:51 AM
Semper Fi
TClev's Avatar
Quoted: 2 Post(s)
Garage
There are a few threads on this subject. You might want to check out what PoPo did here:
Rhino line rocker panels
I'm not sure if he did the wheel wells, but I've been considering doing the same thing. I want the rocker panels, wheel wells, and the bottom inside of my doors done. Heck, if I could, I'd do the entire undercarriage.
Tony Clevinger
06 F250 6.0L Auto Trans - 129,000 mi
Lariat FX4 CCSB
Toyo Open Country 275/65R20
Bilstein 5100s
Edge Evo CTS
Deleted by Scheid Diesel - Lafayette, IN
Bulletproofed by Reckless Diesel - Dallas, TX
CAT EC-1
Rotella T6
XDP Coolant Filtration
Blue Spring
Turbo Oil Feed/Drain Update
Injen Power-Flow Intake
MBRP 5" Stainless TB
Riff Raff Hot Side CAC Boots
6.4 Starter
Upfitter SEIC
TClev is offline
post #4 of 14 Old 09-05-2013, 07:14 PM Thread Starter
Awesome, thanks for the share. I'm just concerned about the rust atm. I'd love to go all the way to the body line all the way around and get the wheel wells as well.
post #5 of 14 Old 09-17-2013, 04:14 AM
phantom-3k's Avatar
Quoted: 14 Post(s)
Garage
So I ended up doing it this past weekend. I used Duplicolor Bed Armor. I think it ended up coming out nice, but if I were to do it again, I would probably just use the Duplicolor bed liner.
I tapped it off and went to town sanding, enough just to rough it up and clean it really good. I rolled on 2 coats, and also rolled on 2 coats on the the fender flares. The stuff is paintable and you can layer it at any time. So I might end up with another coat on it.
Over all I think it looks good, managed to sand out the rust and seal and cover up the cut out I had to do because of rust.
Dave Lenharr #213
Add me!
New Truck!
SOLD
post #6 of 14 Old 09-19-2013, 10:05 AM Thread Starter
Very nice! So the fender flares were able to fit onto the truck over the liner?
post #7 of 14 Old 09-23-2013, 06:29 AM
phantom-3k's Avatar
Quoted: 14 Post(s)
Garage
Yup! I did a lot of research on the flares, needed to find ones that I knew would cover up my cut out after I sealed it with bedliner. I also knew the Bushwacker flares are a good brand to stick with, the molding to the truck and what not. When I installed them, they "hugged" the truck very nice. There is a rubber gasket/sealer that goes on the edge of the flare that meets the truck body as well. I can't wait till I can afford to get the front ones!
Dave Lenharr #213
Add me!
New Truck!
SOLD
post #8 of 14 Old 10-08-2013, 10:50 AM
Really the best thing to neutralize rust is to sand it off but there are products out there that do neutralize well. the best type being the jelly that you need to clean off after it works then prime.
I will suggest Raptor Liner i did it to my truck and i like the texture much better than hurculiner's, rough enough you could cut yourself.
another brand of fender flares would be Stampede this part number should be the ones if you want pocket style, 8404-2. my
08 F350 CCSB Lariat - massaged exhaust, MiniMaxx, AFE Stage 2, Flo-Pro CAC pipe, CCV modded 2" leveling kit. soon to come - EGR delete, sinister intake elbow
Traded in 06 F350 CCLB - 5" diamond eye exhaust, sct (removed before selling), coolant filter, high idle
Zeek is offline
post #9 of 14 Old 10-08-2013, 01:33 PM
gotta_gofast's Avatar
Quoted: 61 Post(s)
+1 for raptor liner. Much better and even texture. I did my rocker panels and wheel wells after sanding and POR15. Its a two part mixture that I sprayed at 65psi. Looking at the above pictures, I'd be stripping it down and doing it again. Looks like you mixed in pebbles when you rolled it on!
'06 F250 FX4 6.0L typical bolt on
gotta_gofast is offline
post #10 of 14 Old 10-09-2013, 04:54 AM
phantom-3k's Avatar
Quoted: 14 Post(s)
Garage
That is the, unfortunate, but it is part of the bed liner. As I said, I wasn't to sure on the "Bed Armor" instead of the regular Duplicolor Bed Liner. The spots you see are kevlar/rubber pieces that would give a bed liner a no stick and rough surface.
This is all great for a bed liner, but I'm not real set on using it as I did. I would use the regular Duplicolor Bed Liner. I did the prep work correctly, sanded down any rust I found too. I like it, but not 100% on it. They say it is paintable, so maybe down the road a gloss black or paint matched paint will go over it.
Dave Lenharr #213
Add me!
New Truck!
SOLD
