Camper Shells - Who has them, and which one(s) do you like? - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 22 Old 08-14-2013, 02:24 PM Thread Starter
Howdy everyone -
I've been looking at camper shells lately and am wondering what everyone is running out there. I've looked at several different companies, but each one has about 10 different models so it's hard to get a good comparison.
What brand/model are you guys running? What are your likes/dislikes? Would you get the same one again? How easy it is to take on/off?
I do know that I don't want/need a rack on top, as I won't be hauling any bikes or anything up there. I also don't want one that opens on the sides; I only need the rear flip up window. I've looked at a lot of Leer models online, as well as SnugTop and A.R.E. I couldn't tell you the difference between them though, other than some models costing more than others.
I'll probably end up going somewhere in the middle as far as price; I don't necessarily want a top of the line model, but I want something better than the base. I plan on keeping it on most of the time, but will be removing it for some occasions.
FYI, this will be going on a 2006 F250 shortbed. Post some pictures up if you have some.
Thanks!
MTW Stage 1
4" MBRP Exhaust
SCT Custom Tunes
Stock TTY Head Bolts
TexasA&M is offline
post #2 of 22 Old 08-14-2013, 02:32 PM
Raul@Stealth Automotive's Avatar
I dont have one yet but i am looking to get a ARE for our Sema build
Raul@Stealth Automotive is offline
post #3 of 22 Old 08-14-2013, 02:33 PM
Quoted: 28 Post(s)
I have an ARE Z-series. I picked that one for a few reasons.
1. No exterior bolts or plugs on glass(sleek look)
2. Carpeted interior
3. Flip down front widow so I can clean the glass or vent really good for the dog
4. Power lock in the glass flip up door that prevents tailgate from opening. Granted a hammer is all people need to get in the back of my truck but it keeps honest people honest...
mtpolarbear likes this.
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #4 of 22 Old 08-14-2013, 03:00 PM Thread Starter
How does the power lock work? Do you have a separate clicker for it? I like the sound of that, since my tailgate lock is broken (I think it was replaced with a junkyard handle before I bought it, so the key does not work in it.
MTW Stage 1
4" MBRP Exhaust
SCT Custom Tunes
TexasA&M is offline
post #5 of 22 Old 08-14-2013, 03:02 PM
alaskan155's Avatar
Quoted: 60 Post(s)
been looking at the are's when i get some money, i want the one with the flip out front window and roof rack system, think they look nice and decently priced.
for now i just have $200 craiglist one, not sure on brand but it seems to be built nice,
its from a obs power stroke, so figure there is some money in it when i decide to sell it and upgrade
have you looked on Craigslist, sound like you want the base model/contractor top
and all of them are going to be the same on taking them on or off, the all usually come with the c-clamp mounts, or you can set it up like mine, i have 4 harbor frieght c-clamp that i can unscrew by hand and remove if i want to take it off on each side, or like my grandfathers who was afraid it was going to blow of his truck and drill holes and bolted to the bed haha
2002 F250 7.3/JW Tow master 4r100 210k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #6 of 22 Old 08-14-2013, 03:12 PM
mach65's Avatar
Quoted: 138 Post(s)
Americraft… painted to match factory color, sides that are molded over the bedrails, flip up side windows, interior lights, top height matches cab, looks like it rolled off the assembly line attached to the truck.
2005 Lariat CCSB
Stock Motor
124,500 miles
edge insight cts/egt probe
coolant pressure gauge in cab
high idle mod
muffler delete
cat delete/stock straight pipe exhaust
IPR coolant filter
EGR welded shut
mach65 is offline
post #7 of 22 Old 08-14-2013, 03:20 PM
layson's Avatar
Quoted: 82 Post(s)
I have an ARE Z-Series. Very nice setup. It is however, VERY heavy! Not something that is easily moved around....LOL
2001 - 14" OUO 525 - 38x15.5x20 Toyo & 20x12 Weld Cheyenne's. Hybrids, 38R, BTS, Spearco, Terminators..
Quote of the Day:
Originally Posted by Mannysouza View Post
You will get some axle wrap with a heavy trailer, I can feel it when towing my gooseneck with some heavy equipment. My Deavers will wrap enough to make the tires rub the front of the rear fender well if I give it too much throttle on aceleration.
layson is offline
post #8 of 22 Old 08-14-2013, 03:20 PM
layson's Avatar
Quoted: 82 Post(s)
Keep an eye on craigslist. That is where I found mine, was just a mile from my work!
Quote of the Day:
layson is offline
post #9 of 22 Old 08-14-2013, 05:00 PM
Quoted: 28 Post(s)
It uses the existing keypad and operates lick a passenger door. Double unlock unlocks it
It taps into the existing wires by the drivers seat and you run wires back to the glass. Well if you get it from a are dealer they will do that for you.
06 350 CCLB
Edge CTS
ARP's
Coolant filter
rentstdi is offline
post #10 of 22 Old 08-14-2013, 05:02 PM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
Leer model 100XQ painted to match. I am not a big fan of camper shells but this was on the truck when I got it and I haven't cared to remove it yet. I like it because it has relatively dark glass but I have had problems of it locking itself...I hope its not haunted
"Pickle Monster"
2004 F-350 King Ranch built 3/24/04
4" lift, 5" MBRP TB back exhaust
EGR MIA
,ported intake, 05-07 intake horn
CCSB
FX4
Firestone airbag suspension in the rear with on-board compressor
Monitored with Edge Insight CS, tuned by Gearhead
high idle mod, Atlas 40 FICM tune, Cat ELC,
2008 taillights, 08 mirrors, smoked marker lights, harpooned fuel tank, DIY headache rack, Bushwacker fender flares
Ford_Fan1 is offline
