2011 bumper on a 2007 - Ford Powerstroke Diesel Forum
post #1 of 9 Old 08-10-2013, 08:29 PM Thread Starter
Bolt on? I seen a 7.3 with a 07 grill and 11 bumper. Looked good.
07 F250 6.0 KR CC FX4
johnwayne1982 is offline
post #2 of 9 Old 08-10-2013, 08:30 PM Thread Starter
I need a new bumper and wanna go this route
post #3 of 9 Old 08-10-2013, 08:52 PM
6.0newb!'s Avatar
Quoted: 14 Post(s)
yup 2011 bumper bolts right up. just have to drill a hole on passenger side to lower the spare tire
06 f-250 ECSB xlt fx4, MBRP 4" cool duals, AFE stage 2 intake, BPD water pump, BPD egr cooler, stc update, stand pipes, dummy plugs, blue spring, late 04 up pipe, wicked wheel 2, PMM coolant filter, Riff Raff ic boots, t6-5w40, Rotella elc, leveling kit with 350 blocks, Pro Comp pro runner shocks, full Powerstop z36 brakes, PHP ficm tuner, insight cts w/egt, SCT x3 with canned tunes...... for now
6.0newb! is offline
post #4 of 9 Old 08-10-2013, 08:54 PM Thread Starter
I meant front sorry
post #5 of 9 Old 08-10-2013, 09:00 PM
alaskan155's Avatar
Quoted: 60 Post(s)
i saw one on here that was on craiglist a while back.... doubt the picture is still up... not sure how they mounted or anything, it was the front bumper
i didn't like how it looked/but some other members did, so it is definitely doable
2002 F250 7.3/JW Tow master 4r100 206k miles
Mods:explorer heater valve, WR GP relay, RiffRAff boots, lariat overhead console, Hydra chip, 6637 mod, 6.0 cooler, AIH delete and isspro2 trans, egt, and boost gauges. 92 gallon aux tank with a total capacity of 130gallons, 1800 mile range
, 4" MBRP straight Piped. 2" Warrior shackles
alaskan155 is offline
post #6 of 9 Old 08-11-2013, 09:12 AM
6.0newb!'s Avatar
Quoted: 14 Post(s)
Originally Posted by johnwayne1982 View Post
I meant front sorry
Haha gotcha, my bad
6.0newb! is offline
post #7 of 9 Old 08-19-2013, 02:46 PM
william_ace's Avatar
Quoted: 2 Post(s)
Who's got a picture for us? I've only seen two. One looked good, the other looked bad.
2004 CCLB 6.0 6 speed 4x4
ARP Studs with OEM Gaskets
Barder Stage 3 / Holders 205/100s
Southbend Dual Disk Clutch
Odawg fully ported and deleted intake manifold
4" MBRP Turbo Back
Windrunner regulated Return with custom Y-pipes
Cat EC-1 with coolant filter
Flyin Diesel Sump w/ fuel lab 4201
william_ace is offline
post #8 of 9 Old 08-22-2013, 01:10 AM
Stroking4ever's Avatar
Send a message via Yahoo to Stroking4ever Send a message via Skype™ to Stroking4ever
There was a guy running around my area that had a 2012 front bumper on his 03 f250. From far away it looked good but as soon as you got close you could see the major gaps and fitment issues. He had a Cummings conversion so i don't know if that caused fitment issues or not. I think it looks better on the 05-07 rigs because the larger grille fills more of the gaps in. But the 2011+ front bumper's are much shallower then ours so the fender line will not match up with the bumper. There will be a couple inch gap. You can see in the second pic the bumper line and fender line are pretty far off, one reason i don't think the guy took any side pics of the truck. Honestly though if you take your time maybe mod the bumper a bit i think it would look very good. Hope this all helps
This is what he had said on his post:
Posted by Hossified of Powerstrokenation; So I just so happened to have a few 2012 F-350 take-off front bumpers laying around my house and the mounting looks really similar to the mounting for my 2001 F-350. I figured 'what the heck' and decided to try to mount it up. Sure enough the bottom bolt holes match directly up with the top holes on the frame bracket and the spacing is dead on with the captive nut holder bracket. Two upper holes drilled and Bob's your uncle. Not sure if it's been done before but thought I'd share the results. (I also did the 05/06 headlight conversion)
Linky to the page: 2012 Front Bumper Conversion on 2000 F-350 - PowerStrokeNation : Ford Powerstroke Diesel Forum
Stroking4ever is offline
post #9 of 9 Old 08-22-2013, 06:20 AM
F250SixOH's Avatar
Not a fan at all
F250SixOH is offline
