Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 05-06-2008, 10:33 PM
Homeslice Homeslice is offline
WILL 37'S FIT WITH A 6'' LIFT
Wll the 37's rub on my 04' with leafs in the front with just a 6'' lift
Old 05-06-2008, 11:15 PM
bigcountrysg bigcountrysg is offline
duct tape & zip ties
yes they will fit.
Old 05-07-2008, 03:02 AM
kinghawg98 kinghawg98 is offline
and yes, they will rub, but not a ton
Old 05-07-2008, 04:04 AM
Rob Rob is online now
Free Faller
Send a message via AIM to Rob Send a message via MSN to Rob Send a message via Yahoo to Rob Send a message via Skype™ to Rob
i have a 6'' pro comp, with 37'' Toyo's/ yes tehy fit, yes they rub, but only on extreme turns.
Old 05-22-2008, 07:24 PM
rolltideroll989 rolltideroll989 is offline
I am going to do a 6" lift and run 20x10 moto metal 951 wheels, what is the max width to do on a 37 without any major rubbing. I was thinking 37x13.50's but was not sure if i could go wider
Old 05-22-2008, 07:48 PM
Diesel Freak Diesel Freak is offline
Rice Hunter
I'm running 37s on a 6" lift. It's doable....... minor rubbing like Rob states
Old 05-22-2008, 08:10 PM
eric99f250 eric99f250 is offline
just get a rim with a really negative offset like the dc-1's
Old 05-23-2008, 08:56 AM
caryt caryt is offline
A wheel with a lot of offset will just help take out your unit bearings faster. Get the correct offset and don't go wider than 12.5" on the tires. Adjust the knuckel stops to keep from rubing the springs.
Cary
Old 05-23-2008, 09:10 AM
RC51 RC51 is offline
cj41foleyisathief
Cary
X2 on the bearings going out and if you run a big aS$ front bumper X4 faster.
Old 06-11-2008, 03:53 PM
Dash71121 Dash71121 is offline
buddy of mine is running 37x13.5's with a 6", looks great and doesnt rub much, no need for a bunch of negative offset
