Which wheels will fit my truck - Ford Powerstroke Diesel Forum
post #1 of 15 Old 08-07-2013, 02:01 PM Thread Starter
I'm looking for the 20 inch king ranch/or 20 inch stock wheels off later year model trucks than mine (2005) f-350 KR 4x4.
I'd like to buy a set of factory takes offs. My question is what years fit my truck?
Thanks to everyone for your help!
Sent from AutoGuide.com App
05WhiteKR is offline
post #2 of 15 Old 08-07-2013, 02:06 PM
RollinEarly99's Avatar
Quoted: 8 Post(s)
Feedback Score: 10 reviews
The bolt pattern hasn't changed on the super dutys, but since you have an 05 the brakes are larger than 99-04 so you need to have 17's or bigger to clear the front brake calipers.
05 F-250 Crew Cab Short Bed
ARPs w/OEM Gaskets
MTW Stage 2 w/batmowheel
BPD oil cooler w/ cold weather package
BPD Updated umm...Everything
BPD bypass oil filter
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
Custom grille made by Me
X3 w/Matts SRL+/SRLxx and Tow Tunes
Tony WildmanExtreme w/early lockup
RollinEarly99 is offline
post #3 of 15 Old 08-07-2013, 04:02 PM
USAFBowman's Avatar
I believe in 08 they did change... but 99-07 they are the same.
USAFBowman is offline
post #4 of 15 Old 08-07-2013, 04:12 PM Thread Starter
I'm wanting 20x9 or 20x10 stock wheels. So any year super duty wheels will fit?
If I went aftermarket what would the back spacing be and all?
post #5 of 15 Old 08-07-2013, 06:17 PM
Quoted: 8 Post(s)
The bolt pattern is the same in all years...8x170
The wheel studs changed...99-02-14x2.0 03 and up-14x1.5
Studs size doesn't matter because it can me fixed with a simply lug nut change.
ARPs w/OEM Gaskets
BPD FICM 58v
Spring Mod
Egr deleted
4" Duals
Edge CTS
post #6 of 15 Old 08-07-2013, 07:37 PM
wheels
I have a 05 4x4,and have had the 2009 20s on mine and now have the 2012 KR 20s. but stock it came with the 18s
badash is offline
post #7 of 15 Old 08-08-2013, 07:47 AM Thread Starter
Ok so if I'm understanding correctly I can put any year newer wheels than 2005 on my truck without any modification?
post #8 of 15 Old 08-08-2013, 06:49 PM
rims
from my experience yes.
badash is offline
post #9 of 15 Old 08-08-2013, 06:54 PM
BIG Laing's Avatar
Ford hasn't made and 20x9 or 20x10 wheels... Yet.
All SRW 20" wheels 05 and newer are 8" wide with a +40 offset on a 8x170 bolt pattern.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #10 of 15 Old 08-08-2013, 06:56 PM
BIG Laing's Avatar
That is correct. You could even put 99-04 SD wheels on, but since the offset on the leaf sprung trucks is a 0 offset they would be sticking out 1.75" further out then your stock wheels.
