Power steering and Brake problem - Ford Powerstroke Diesel Forum
post #1 of 6 Old 07-11-2013, 08:58 AM Thread Starter
I've recently had a issue with my power steering and brakes messing up it feels like my power steering is going out but when you push the brake pedal down it makes the same noise as when turning. I have hydrobooster could the power steering pump be causing this issue. I need a little input?
Gibbons06 is offline
post #2 of 6 Old 08-10-2013, 02:31 AM
check your power steering fluid level, I recently had this problem when my steering gearbox decided it wanted to crack and dump all the fluid. A new gearbox and fluid solved this problem
2003 6.0 F250 "Onyx"
4inch lift
35'' Falken Wildpeak AT
SCT FX3 Performance tune
Edge Insight CTS
Edge EGT probe & Fuel Pressure sensor
Blue spring upgrade
Bulletproof Diesel EGR Cooler
Updated Motorcraft Oil Cooler
Sinister Diesel Coolant Filter
Rotella ELC
MBRP 4'' Turbo Back SS Straight pipe
Alpine head unit
Rockford Fosgate speakers
Still need to stud it....
aeby07 is offline
post #3 of 6 Old 08-10-2013, 05:57 AM
kinnisoj's Avatar
Quoted: 2 Post(s)
Would also be a good time to look into doing the power steering fld flush. Very easy and you might be suprised how cooked the fld is.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #4 of 6 Old 08-10-2013, 06:59 AM
HP MACHINE's Avatar
Quoted: 119 Post(s)
My 2004 has a mind of its own once and a while , steering on its own from side to side.
After hard acceleration it goes stupid then when things tame down it's fine - sometimes
during early driving while the truck is coming up to temp.
I put a magnefine filter in the line from the booster to the tank - not sure if that was
a good idea ?
I'm going to change my fluid and move the filter to the return line at the cooler.
Any thoughts would be appreciated
HP MACHINE is offline
post #5 of 6 Old 08-11-2013, 06:47 AM
Possibly an intermittent problem in your power steering pump? Could possibly be losing pressure, then gaining it back to give you that side to side steering feeling. The pump could also be having a hard time regulating the output pressure when you accelerate hard causing it to "go stupid".
4inch lift
Edge Insight CTS
Blue spring upgrade
Rotella ELC
Alpine head unit
aeby07 is offline
post #6 of 6 Old 08-11-2013, 01:51 PM
305f250's Avatar
Pump is going (or working to hard) when it screams like crazy so you can narrow it down.. And just for a warning, im sure you already know butttt we use atf fluid not power steering fluid.
305f250 is offline
