ugly side molding ideas?? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-07-2013, 05:48 PM Thread Starter
So I have the dumb factory side moldings on my truck. There all faded and starting to peel off the side of the truck. I yanked off the passenger side door one and was gonna rip the rest off till I noticed the paint was all bubbled under it. I got 3M molding tape and re taped it and it still don't look right. I have the tan lower on my truck which I am starting to get tired of looking at so I was gonna get the bottom sprayed with line x. Will the line x fill in the paint bubbles if I clean them out? So I'm asking do you guys think it would look better with new side moldings and line x bottom or should I just take off the moldings and go higher up with the line x? I looked at some trucks with it done but still can't decide. What do you guys think??
6ohslow is offline
post #2 of 12 Old 07-07-2013, 08:19 PM
HarvestingInternationally's Avatar
Have the same bubble issue on my driver side dooor
http://img716.imageshack.us/img716/2580/oppt.jpg
2006
F250 Crew Cab Long Bed 6.0 TurboDiesel FX4
Diesel Site Coolant Filter, Edge Insight CTS, BPD FICM 48v, Metal CAC Tube, Blue Spring,Sinister Diesel EGR Delete w/ Up Pipe, Riff Raff Boots, MBRP 6212-409 Exhaust, BFG AT's,
Bilstein 5100's with Leveling Kit, ISSPRO EV2 Gauges (Pryo
, Fuel Pressure)
Eric
HarvestingInternationally is offline
post #3 of 12 Old 07-15-2013, 11:54 AM
mattmann86's Avatar
Subbed.
I asked this question a while ago about my trim looking bad and didn't get to much on it. Most people said take them off but they have saved my doors a lot of dings by looking at them so that's a no go. Wish there was a way to refinish them?
mattmann86 is offline
post #4 of 12 Old 07-17-2013, 08:24 AM
mattmann86's Avatar
No one? Would plasti dip fix this? If one were to tape the truck off and spray the trim?
post #5 of 12 Old 07-17-2013, 08:56 AM Thread Starter
I plasti dipped several plastic parts for over a year now. Looks good still and ez to touch up. I never used the white tho only black.
6ohslow is offline
post #6 of 12 Old 07-21-2013, 08:52 PM
mattmann86's Avatar
Update!!!!
A freaking magic eraser cleaned my side molding right off and looks brand new
post #7 of 12 Old 07-23-2013, 03:42 PM
trophy_23's Avatar
That cleaned up the dings? Mine are black and seem to be going dull in areas I don't know what will fix that other than replacing them.
2007 F350 SC FX4 Lariat
Edge Insight CS w/ Pillar Mount & EGT
SCT with Gearhead Tunes
ARP Studs & EGR Delete
High Idle
Duraflaps
Back Rack & Tool Box
LED bed & toolbox Lighting
4 Hella's Behind the Grille
18W LED Hitch-mount Back-up Lights
Dually ID Bar
**You could be the one match to save a life!!**
trophy_23 is offline
post #8 of 12 Old 07-23-2013, 04:09 PM
mattmann86's Avatar
Don't know about black as mine are white. Obviously didn't get rid of the dings lol.
post #9 of 12 Old 07-24-2013, 08:58 AM
trophy_23's Avatar
I meant like did it get rid of scuff from the dings? Im going to try it on mine.
High Idle
Duraflaps
Dually ID Bar
post #10 of 12 Old 07-24-2013, 09:01 AM
mattmann86's Avatar
It did on mine,!
