05 mirror upgrade? - Ford Powerstroke Diesel Forum
post #1 of 22 Old 06-17-2013, 07:50 AM Thread Starter
05 mirror upgrade?
Have a 05 f250,has the small paddle mirrors on it,want to upgrade to the bigger towing style mirror,want a set that has the signal lites in them,my question is will the lites work with my factory harness,are they normally wired for them.or will I have to run my own wires?my mirrors I have are power ones,the new ones will be power as well.I also am looking at the 08 and up ones too,but will most likely buy the 07 ones,seems to be lots on evil bay. Harvey
Dark Satin 05 is offline
post #2 of 22 Old 06-17-2013, 08:19 AM
RRF985's Avatar
The 05-07 tow mirrors are plug and play. The lights in them will work when you plug them in. If you get 08+ you may have to do some wiring.
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
post #3 of 22 Old 06-17-2013, 08:42 AM Thread Starter
Cool,thats what i was hoping for. thanks Harvey
post #4 of 22 Old 06-18-2013, 04:32 PM
kawika904's Avatar
I have a 2005 ex. had stock towing mirrors with running and turn signal lights that looked like these
2005 Ford F250 Truck Super Duty Mirror Power Heated Signal Dual Arm Telescoping Textured Black Pair at 1AAuto.com
Did an upgrade to these that are plug and play.
2003-2007 Ford F250 Truck Super Duty Power Heated Smoked Style Signal & Clearance Light Textured Cap Upgrade Towing Mirror Pair at 1AAuto.com
Straight swap, no wiring needed and only took about 20 min. Amazing how much more you can see with the new mirrors. Hope this helps. Good luck
2005 Excursion Limited 6.0L, Zoodad, Insight CTS w/Pyro and fuel pressure, blue spring, Coolant filter, Rancho RS9000xls w/ MyRide wireless, DC power alternator, Tekonsha P3, Door seal mod. 08+ style tow mirrors, Stainless braided brake lines, Powerslot cryo rotors, Hawk LTS pads, Britebox So far.....
kawika904 is offline
post #5 of 22 Old 06-18-2013, 04:34 PM
USAFBowman's Avatar
They have 08 style ones direct plug and play such as i have on my truck on Am-autoparts.com
USAFBowman is offline
post #6 of 22 Old 06-22-2013, 12:22 PM
I have an 03 6.0 with the power paddle mirrors, will those be plug and play also?
2003 6.0 F250 "Onyx"
4inch lift
35'' Falken Wildpeak AT
SCT FX3 Performance tune
Edge Insight CTS
Edge EGT probe & Fuel Pressure sensor
Blue spring upgrade
Bulletproof Diesel EGR Cooler
Updated Motorcraft Oil Cooler
Sinister Diesel Coolant Filter
Rotella ELC
MBRP 4'' Turbo Back SS Straight pipe
Alpine head unit
Rockford Fosgate speakers
Still need to stud it....
aeby07 is offline
post #7 of 22 Old 06-23-2013, 01:46 AM
Island Dweller
Qholic's Avatar
Quoted: 58 Post(s)
If your paddle mirrors have lights in them they should be plug and play if you do not have the signal lights in your going to have to come up with a solution.
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #8 of 22 Old 06-24-2013, 01:10 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
Go 08+ and never look back.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 22 Old 06-24-2013, 02:34 AM Thread Starter
If i was to never look back,wouldnt that defeat the purpose of the mirrors. i really like the 08 and up ones better,just trying to justify the extra cost,only pull a trailer 2-3 times a year,trailer is a 32 foot gooseneck enclosed car trailer,it is really hard to see back there. that thing blocks a lot of sunlight on back there. Harvey
post #10 of 22 Old 06-24-2013, 05:09 AM
Island Dweller
Qholic's Avatar
Quoted: 58 Post(s)
I rarely tow however for moving in and out of traffic it's nice not having any blindspots.
sent from my Samsung S4
Shawn
Qholic is offline
