| 6.0L Exterior Discussion Body and Accessories Talk |
4" lift uneven from side to side
I've got a 2004 F350 ext. cab short bed with a 4" skyjacker lift kit
Drive it alittle bit to move everything around. Make sure you are on flat ground. My F-150 is off my 1 - 1 and 1/2 inchs on the passenger side.
I read a few post like yours and you are not the only one out there. It seems to be normal. Maybe because of the fuel tank.
sitting level now. Thanks guys. Just have to fix the steering wheel now. drives straight, but wheel is tilted. You guys know if its only the two bolts to pop the wheel off?
I have a 4" skyjacker (blocks rear) and it sits DEAD LEVEL. Usually when you have leafs all around it's prone to un-eveness. Which is what I think is happening with you... Leafs on all 4 corners. My rock crawler did the same thing. it will change from time to time which way it leans. the Coil front end really helped out with leaning issues. Coils are much more precise. Don't forget... the more height.. the more noticable/worse the lean is!
I just put 2.5" leveling spacers below my coils.
measured wheelwells b-4 and they were 3/4'' off same after kit installed. ![]() Cant see it standing back, or driving by. Last edited by TURBODIESELWAGON; 03-26-2008 at 06:06 PM. |
Get a heavier girlfriend.
normal....I measured mine b-4 & after...same difference ![]() cant see it without the tape measure! |
more skidmarks than a get-a-way car....huh?
Don't take the steering wheel off to adjust .. the bar I forget what its called but its the one running down from your pitman arm it has a link in the middle you trun to adjust steering or aka alignment
