| 6.0L Exterior Discussion Body and Accessories Talk |
Tell me about your leveling kit
Guys, Im looking at getting a 2.5" leveling kit for my 06. Tell me about what you have. What Im needing to know is
Whos kit? How did you fix the track bar? What did you do for rear lift? Anything else I need to know? Thanks alot guys! Colin C |
I have a 2.5?" SkyJacker spacer up front and a Rancho add-a-leaf in the rear, stock shocks- which should be replaced with longer ones because they bottom out. I clear my 35x12.5x17's with no problem and it sits nice and level!
Ive got a Skyjacker 2.5 lift kit for sale heres the link
http://www.powerstroke.org/forum/sus...g-kit-f-s.html |
I've got a 2" spacer kit that goes beneath the front coil spring. I got it on ebay for about 35 bucks.
I didn't do anything with the track bar. The front end is still pretty much centered. I am concerned about the change in the caster angle, but I've been told not to worry about. I didn't do anything for the rear lift. I have an F350 with about 4" blocks and an overload spring. The truck still has a slight rake. |
Got any pics BigRed?
I also have the 2" solid alum. spacers that i got through eBay. I've had them on for at least 5K and they've been great. Was able to put on 35's on the stock wheels w/ no probs. For $35, u can't beat it. Sits perfectly level, if u wanted a slight rake, u could add blocks or an add-a-leaf to the back.
Guys using the spacers (like the Ebay ones), have you noticed in difference in the truck's handling? Does the steering still return to center after a turn? Does the truck wander down the road?
Ryan |
The handling has seemed the same to me. Put a dual steering stabilizer on at the same time to handle the 35's, so that might have helped.
hey was just wondering what everyone thought of this kit ICON VEHICLE DYNAMICS, and also just read up on the sulastic rubber spring, https://www.sulastic.com/default.aspx
new to this forum and trucks, soo im trying to do plenty of research before i go into modding my truck.... also would be looking into a dual steering stabilizer setup, and tires, but am not aware what are the largest tires u could fit on the factory 18's .. |
