Anyone running a Air Ride set up? - Ford Powerstroke Diesel Forum
post #1 of 10 Old 06-10-2013, 09:54 AM Thread Starter
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Looking to get one for the 550. Checking to see if anyone has used or is using one on there truck.
Tom
5" MBRP Straight Exhaust w/ 6" tip, SCT Monitored, Limo Tints, 20" LED Lightbar, 8k HIDS, & Some other goodies
Other Rides
1978 Trans Am Y88 403 84k original miles
1996 Ford F350 PSD Mason Dump 134k Original Miles!
Gone But Not Forgotten... (Lilah) 2008 Ford F250 Lariat CrewCab
Proud To Be An American!
tkobes43 is offline
post #2 of 10 Old 06-10-2013, 10:29 AM
Ford_Fan1's Avatar
Quoted: 6 Post(s)
Feedback Score: 3 reviews
I got air bag suspension made by firestone on the rear axle of my f350 and I love it. It was equipped with it when I bought it so I don't know about installation but I can say that it rides very nice and since mine has the on-board compressor I can increase or decrease air pressure with the flip of a switch instead of crawling under it with an air hose.
Name:	air bag susp.jpg
ID:	122890   Click image for larger version
Name:	air bag susp1.jpg
ID:	122898   Click image for larger version
Name:	air bag susp 2.jpg
Ford_Fan1 is offline
post #3 of 10 Old 06-10-2013, 05:10 PM
aussie=effie
bob harris's Avatar
air ride set up
yep, love my Firestone set up, can even use the compressor to do tyre pressures when I need to
bob harris is offline
post #4 of 10 Old 06-18-2013, 12:26 AM
rebelranger's Avatar
Do you use this even unloaded?
rebelranger is offline
post #5 of 10 Old 06-18-2013, 01:08 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
Yep I have the Firestone system,its a great setup.The only issue, is I have had a few pressure sensors go out on me,but Firestone did replace them for free.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #6 of 10 Old 06-18-2013, 01:09 AM
Motor Head.
robertc68's Avatar
Quoted: 39 Post(s)
You have to keep at least 5 lbs of air in them.
post #7 of 10 Old 06-18-2013, 01:11 AM
I have the same on my 350
You keep 5 lbs in it when unloaded just in case you hit a large hole
So the bags do not get pinched.
But it makes a huge difference when loaded, just reach in the console
And hit the switch till it levels out.
Stops all the light front end effects when heavily loaded.
MRImike is offline
post #8 of 10 Old 06-18-2013, 08:27 AM Thread Starter
tkobes43's Avatar
Quoted: 2 Post(s)
Garage
Would the firestone airbags work in my 550? Whats the max weight they can handle?
Tom
Other Rides
tkobes43 is offline
post #9 of 10 Old 06-18-2013, 08:32 PM
How does it affect the ride quality both unloaded and loaded? 5lbs isn't much pressure alone.
post #10 of 10 Old 06-18-2013, 08:37 PM
1armbandit's Avatar
ive got it on my truck and its been a nice thing to have. I looked on there website and it says they make one for the f-550 but doesn't say the max weight they can handle
2004 Black F-250 Fx4 ranch hand bumpers, banks exhaust straight piped, K&N cold air, firestone air bags, Truxxx leveling kit, 35 inch bfg a/t
1armbandit is offline
