coil spring spacers ??? - Ford Powerstroke Diesel Forum
post #1 of 5 Old 06-09-2013, 06:39 AM Thread Starter
They make to sit on top of spring and to fit under spring. Any pros or cons with either? Any opions which is better? thanks
2006 Ford Powerstroke Super Cab 4x4 auto 120K bulletproofed
ramz trk is offline
post #2 of 5 Old 06-09-2013, 06:41 AM
powerstrokecrzy's Avatar
Quoted: 228 Post(s)
Just installed the ones that go under a couple weeks ago. pretty easy install and no problems so far
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #3 of 5 Old 06-09-2013, 11:46 AM
I put a pro-comp 2.5" leveling kit which included top mount spacers and shock extensions.
zero issues, just make sure you get an alignment right away.
Rotasol is offline
post #4 of 5 Old 06-11-2013, 11:44 AM
happyhrs's Avatar
bottom mounted
I installed the bottom spacers last month, no problems. Brought in for alignment(didnt need one)
2005 F350 PS
4" Banks exhaust
Airraid intake
Edge cs
Juice w attitude
Bilstein Shocks & Stabilizers
Firestone rear airbags
onboard air compressor
Texas train horns
Blue Spring Update
happyhrs is offline
post #5 of 5 Old 06-11-2013, 12:08 PM
GregsSD's Avatar
Quoted: 15 Post(s)
Garage
I used the Daystar spacers that go on top of the springs with a pair of longer shocks, worked great and I did not have to get it aligned afterward.
Either style of spacer should work fine, just remember that you need to either put shock extensions on, or put longer shocks on. Otherwise you will end up with a harsh ride because the stock shocks will be maxxed out in length.
2005 F-250 CC/SB 4x4 medium wedgewood blue
5" lift, 5" Donahoe rear springs, 35x13.50 MTZ's, 18x12 Fuel Hostage wheels, 4.30 gears, Banks 4" exhaust, Airraid intake, SCT from Innovative, ARP headstuds, Bulletproof ficm, Scangauge II, Randy Ellis Design lightbar, Street Scene flares, Harpoon mod, Zoodad mod, LED 2010 taillights, Switchback LED front turn signals
GregsSD is offline
