| 6.0L Exterior Discussion Body and Accessories Talk |
best place to get ball joints...?
ive heard moog is the way to go..anyone have any input or recommendations?
check out powerstrokeshop.com. This is where i bought mine from. I paid 248 and change for the whole moog kit with axle seals. I think they are still running a special on the ball joints.
Moog's are great, just don't use the 90* zerk fitting on the top ball joint - it'll hit the axle shaft Ujoint in 4wd and could eventually break off... Just grease it before installation, then put the regular cap on it. In the future you can reinstall the 90* zerk while the ball joint is still installed and grease it... but it just takes some time.
While you're in there - you might want to consider the Dynatrac hub system being that you're increasing the size/weight of your tires!
thanks guys..dynatrac system would be great but a lil to pricey right now...
MOOG Baby. They are the only ones I use!!!
