Door adjustment - Ford Powerstroke Diesel Forum
post #1 of 2 Old 05-31-2013, 03:16 PM Thread Starter
Erickettering's Avatar
Door adjustment
Is there any way to adjust my passenger door to close tighter? You can push in on it a good way after its closed. It also sounds like a door that's not completely closed going down the road.
2006 f250 king ranch crew cab 4x4 125k
s t o c k except - scan gauge 2 - egr plugged - sct sf3 with gearhead tunes - high idle mod - ficm soon to be tuned/rebuilt
Erickettering is offline
post #2 of 2 Old 06-02-2013, 11:41 AM
kawika904's Avatar
Do the door seal modification. Do a forum search, lots of info on what it is, and how its done. Cheap, easy usually a half hour, and definate results. Good luck
2005 Excursion Limited 6.0L, Zoodad, Insight CTS w/Pyro and fuel pressure, blue spring, Coolant filter, Rancho RS9000xls w/ MyRide wireless, DC power alternator, Tekonsha P3, Door seal mod. 08+ style tow mirrors, Stainless braided brake lines, Powerslot cryo rotors, Hawk LTS pads, Britebox So far.....
kawika904 is offline
