New Shocks - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-29-2013, 02:43 PM Thread Starter
New Shocks
So I have a rather strange question for you guys and it begins like this...
I've got a buddy with an 05 Nissan Titan and he wanted to get a little lift so he could fit some bigger tires without the rubbing issue. So he found out by putting bigger shocks (taller and beefier) he could achieve a little lift. He also did spacers and blocks but he installed the shocks first before the putting on the actual lift portion and said he actually achieved some lift. Is this possible? If it is possible could this same idea be used on our trucks?
06DieforDiesel is offline
post #2 of 5 Old 05-29-2013, 08:12 PM
I Like Shiny Things :)
nighthawk285's Avatar
Quoted: 1657 Post(s)
Feedback Score: 4 reviews
I'll spare the funning that your friend is a little silly
Shocks (unless rediculously high-valved or part of a coilover system) will never help you achieve any lift. They are made to absorb the shock at a lower rate than your springs (which get you the lift).
2005 King Ranch F-350: Studded and O-Ringed, BPD Oil Bypass, 205/30s, Stage 2 KC Turbo, ODAWG Ported Manifold, 4" TB Exhaust, No Limit Intake, Billet Torque Converter, BPD 58V FICM, BPD Water Pump
2.5" Leveling Kit, 35s, Fusion Bumpers, ProTech Headache Rack, OnBoard Air, and a few other goodies
nighthawk285 is offline
post #3 of 5 Old 05-30-2013, 12:46 PM Thread Starter
haha well thank you for not giving me s**t. I realixe that was beyond a dumb question but he was certain he achieved some lift so I figured I'd ask
post #4 of 5 Old 05-30-2013, 01:49 PM
rdaffin's Avatar
He probably jacked up the front to do the shocks. When he sat it down it will sit higher until you move the truck some. The tires will kind of hold the truck up a little (maybe 3/8 to 1/2" ) until it settled.
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #5 of 5 Old 05-30-2013, 01:54 PM
305f250's Avatar
Ajustable coil overs is the only way your going to raise it up even a little and those suckers cost a pretty penny, just through a spacer or shackle lift and it'll save you a bunch of $$
305f250 is offline
