Another "will 35's fit" !! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-28-2013, 03:55 PM Thread Starter
powerstrokecrzy's Avatar
Quoted: 264 Post(s)
Tried to search but the search function on phone app isn't so hot, anyway... Stock height 2005 f250, -6mm offset, 4.75" backspace, 17" wheel. Will nitto trail grappler in 35 x 12.50-17 fit with any rubbing? I have a 1.5" level kit ready to install but would rather not if they'll fit. Any experience??
05 250. Lariet. 4x4.
arp studs w/oem gaskets & all updates
Warren 175cc/stock sticks
Egr delete
Zoodad
New oil cooler
Coolant filter w/ zerex ec-1(homemade)
4" turbo back, straight piped
SCT livewire (running TSD SPD)
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Ccv reroute (dump to atmosphere)
Air Horn Kit
high idle
Pro comp "bullet hole style" 17" w/ 35" nitto trail grapplers
powerstrokecrzy is offline
post #2 of 3 Old 05-28-2013, 09:05 PM Thread Starter
Quoted: 264 Post(s)
Bump ttt
Egr delete
Zoodad
New oil cooler
KC Turbos 1.5
Blue spring upgrade
riff raff boots
Air Horn Kit
high idle
post #3 of 3 Old 06-08-2013, 03:05 PM
If it's any help, I have an 05 F350 with helper spring and 3.5" leaf block, I had to do a 2.5" front level to get 35X12.5X20 tires to fit. it JUST touches the radius arm on full lock. This is using a stock 20" '08 KR rim.
Rotasol is offline
