| 6.0L Exterior Discussion Body and Accessories Talk |
tire help
I'm looking at putting a set of 315/70/17 on my stock rims. My questions is when I air them down to 20 psi for beach driving will they pop off the bead or will they be ok. They are only 12" wide on a 8.5 rim, so what would that make them on the 7.5 rim? Just need to know people's thoughts and experiences with this size before I spend the money.
What tires are they?
BFG All Terrain tires....what size mud grapplers are you running? they look real good on the truck
Airing them down should be fine. You are squeezing a tire on a rim thats too narrow so the tire is naturally going to put more pressure on the bead holding it in place. I don't know how wide the tread will end up but they will be taller then when on a 9 or 10 in wide wheel. I had 33/12.5R15's on my stock '86 Chevy wheels for years with no problems. Even with low pressure rock crawling in Moab.
thanks R.Taylor, I was thinking that it wouldn't pop off because of the pressure like you stated, but don't want to spend all that money to find out the hard way.
