Which Lift? - Ford Powerstroke Diesel Forum
Old 02-21-2008, 02:08 PM
Which Lift?
Which lift kit would you get or recommend and why? I am currently looking at the Pro Comp 6" Stage II with rear springs and the Rough Country 6" 4 link with rear springs. Money is an object. I would like to stay under $2k, but less is better. I am currently running 35's and may go to 37's in the future. I plan on getting cut-out flares so I dont want to go up to an 8" lift. What are your thoughts?
Old 02-21-2008, 02:10 PM
37's will easily fit under a 6" lift.. no cut out fenders needed..... i would go with the 4 link system
Old 02-21-2008, 02:11 PM
Let's Run'em
To be honest haven't heard great things about Pro-comp and they are alittle over priced for what it is......I heard that Rough Country is a great value buy, what shocks are planning on running and more importantly what do you use the truck for
Old 02-21-2008, 02:13 PM
pro comp 8" lift comes with rear springs and fits 37"s easy for only $1295. Then a 4 link upgrade is only $695. I wouldnt do the cutouts because there aint going back after that.
Old 02-21-2008, 02:15 PM
I have bilsteins now, but will probably run whatever comes with the kit for now and get bilsteins again later. Mostly the truck is used for daily driving. I occaisionaly go off road, when hunting and riding the quads, and do pull a small trailer and large 5th wheel occaisionally. We are actually trying to sell the 5th wheel to down size.
Old 02-21-2008, 02:16 PM
Let's Run'em
Ok and what are the best prices of the two kits that you have found?
Old 02-21-2008, 02:21 PM
Where did you see that at? I dont really want to go 8" since it may be a couple years before I upgrade to 37's. I was actually thinking of the cut outs prior to the lift, but since I am getting a lift now, i may not get the flares. My new wheels are 18x10 4.5" back space, so I know I need some clearance.
Old 02-21-2008, 02:22 PM
$1550 for the Rough Country
$1545 for Pro Comp
Old 02-21-2008, 02:26 PM
Let's Run'em
$1545 for Pro Comp
Yeah your prices seem kinda steep to me.....lets see if maybe on of our vendors can help you out
Old 02-21-2008, 02:28 PM
I am open to other suggestions as well.
