35s on 22s - Ford Powerstroke Diesel Forum
post #1 of 10 Old 04-22-2013, 03:20 PM Thread Starter
35s on 22s
so undecided on what i want to do for wheels tire and lift. live in mass and dont want to go too high of a lift for a couple reasons. really want to run 35s on 22s to keep me from off roading the truck, is this possible with a 4" lift? its a 04 4x4 i really like the rbp 96r 22x9.5 with a +10 os
Lennyk83 is offline
post #2 of 10 Old 04-22-2013, 07:17 PM
cormc's Avatar
Quoted: 2 Post(s)
I had 34/11r22 with -10os with only a leveling kit .your 4"should be more then enough.to clear 35s just make sure you get the proper os so your tires don't rub on your leaves at full turn
cormc is offline
post #3 of 10 Old 04-23-2013, 04:14 AM Thread Starter
Did you like the 22s on the small side wall ride wise? And did you have leaves or springs? Thanks for the info cormc
Lennyk83 is offline
post #4 of 10 Old 04-23-2013, 01:56 PM
cormc's Avatar
Quoted: 2 Post(s)
I loved the 22s still have them with the sane tires but its now lifted but been looking into super singles but have coils . They calll for 70psi in them but I ran them at 60. Rode great tho
cormc is offline
post #5 of 10 Old 04-23-2013, 04:26 PM
Koda22's Avatar
Quoted: 5 Post(s)
I think that's the best tire/rim combo...I cheaped out and didn't get them, but will be my next setup for sure
Koda22 is offline
post #6 of 10 Old 04-24-2013, 12:58 PM Thread Starter
Does anyone know the right back spacing and off set so the tires won't rub at full turn? I don't really want to use wheel spacers and I don't mind them sticking out a little past the fenders. I believe it's 4.5" of bs
Lennyk83 is offline
post #7 of 10 Old 04-24-2013, 01:08 PM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
I believe thats the backspacing for 99-04. the 05+ trucks have 0 backspacing so if you got the wheels that fit 99-04s they would stick out 4.5" but i would make sure they are hubcentric vs. lugcentric for your truck. The aftermarkets sometimes come with the ability to do both
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #8 of 10 Old 04-24-2013, 01:39 PM
Koda22's Avatar
Quoted: 5 Post(s)
0 is the offset...05+ ur gonna want I believe a 5inch backspacing, 99-04 is 4.5
Koda22 is offline
post #9 of 10 Old 04-24-2013, 01:56 PM Thread Starter
It's an 04' so 4.5" of bs with a 0 offset? I don't believe the rbp 96r are hub centric is that a big deal? I've heard yes and no
Lennyk83 is offline
post #10 of 10 Old 04-24-2013, 01:57 PM Thread Starter
Thanks for the help
Lennyk83 is offline
