2" leveling kit for $20 - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 25 Old 04-16-2013, 05:27 PM Thread Starter
legionxxii's Avatar
Anyone seen these before? Looking at lifting the front up just a tad to clear 35s and came across these. Pretty dang cheap and there bottom mount.
2005 2011 4WD Ford F250 F350 2" Leveling Lift Kit | eBay
2006 Ford F250 King Ranch CCSB Stock for now
Sold 2003 Ford F250 Fx4 CCSB 4" Turbo Back Straight Pipe With 6" Tip Egr Delete 6.4 Banjo Bolts Blue Fuel Spring Upgrade Cat ELC Coolant Coolant Filter Edge CTS SCT With IDP Tuning PHP FICM Tuner Zoodad Mod Track Time: 13.747
US ARMY 13F
legionxxii is offline
post #2 of 25 Old 04-16-2013, 08:45 PM
adamread's Avatar
You make your own bed.
If your looking for a cheap way to lift the front a few inches, in a respectable manner, might I suggest PMF's BMC spacer. It's the same idea as what you're looking at there, but as you can see looking at the pictures, maintains the lateral support that the factory piece has built into it. It's still pretty damn cheap.
2005-12 Ford F-250/350 BMC Spacer
2006 F250 CCSB - Full PMF Suspension (3.5" 3-Link, 5.5" Traction Blocks, Drag Link, Track Bar & Steering Stabilizer) Bilstein 5100s, Hellwig's F+R, Centramatics, 20" Harleys, 35" Cooper Disco STTs, Nuc Bypass, Marine Charger, DDEC60 Block Heater, ARB w/ HID Hellas, BPD Water Pump, 5" MBRP Straight, SCT-X3 w/ IDP, H11's w/ OEM Gaskets
Dead in Water - Blew Turbo / IPR
adamread is offline
post #3 of 25 Old 04-17-2013, 07:53 AM
Id like to know to. I have an 05 fx4 ccsb and have been looking at leveling kits.
firewhop3 is offline
post #4 of 25 Old 04-18-2013, 06:32 PM
Legion, did u order the kit from eBay? If so how do u like it?
post #5 of 25 Old 04-19-2013, 12:37 PM
TGauger's Avatar
I used one of these exact kits on my 05 f350 cclb. Worked great. I would recommend getting some shock mount extensions. It was real easy to install and was just the right height.
05 F-350 CCLB, Harley Davidson Edition
TGauger is offline
post #6 of 25 Old 04-19-2013, 07:18 PM
Did you have any alignment issues or anything ?
post #7 of 25 Old 04-19-2013, 07:34 PM
TGauger's Avatar
Drove They do Recommend An Alignment After Install And I Did One, but It Drove Fine On The Way To The Alignment Shop.
TGauger is offline
post #8 of 25 Old 04-19-2013, 07:41 PM
kinnisoj's Avatar
Quoted: 2 Post(s)
My wife got this very kit. Im still hesitant about runnin it.
,edge turbo timer
5" TB DIAMOND EYE EXH
ATLAS 40
TITLE IN HAND...
kinnisoj is offline
post #9 of 25 Old 04-20-2013, 04:28 PM Thread Starter
legionxxii's Avatar
I bought it to try it out. I went through the guys feedback and found some people who bought the kit and asked them how it was and they all said great with no issues. I figured WTH its only $20 I will give it a shot to lol
US ARMY 13F
post #10 of 25 Old 04-21-2013, 06:20 AM
f350powerstroke's Avatar
You're better off getting a pricey leveling KIT. Your tires will thank you..
2007 f-350
SCT Street tune Innovative Diesel
4 inch straight pipe
Bypass coolant filter, ELC
Edge Insight CS
leveled 2.5
130k miles
Infowars.com
REAL TRUCKS DON'T HAVE SPARK PLUGS!
Are U Aware?
f350powerstroke is offline
