Go Back   Ford Powerstroke Diesel Forum > Ford 03-07 6.0L Powerstroke Forums > 6.0L Exterior Discussion
Old 09-14-2006, 12:18 PM
teameyecatcher teameyecatcher is offline
What size tire for a 6" lift on 2wd
I'm wondering what size tire I could actually put under there with the lift... Fabtech says that the 6" lift on a 2wd would fit 315/70-17 (about 34.5") with minor trimming. I know a 6" on a 4wd would easily fit those 35's, but Ford specs show that mine is about 2-3.5 inches shorter than a 4x4...who knows
Old 09-14-2006, 12:48 PM
Marty Marty is offline
International Threat
Besides the obvious question as to why lift a 2wd, I think you should be able to clear those bad boys and if you don't... start looking at saw blades.
The reason the 4x4's can clear larger tires is because they already sit up about 2" higher in the front then the 2wd's. Reason? In 4x4 you need ground clearance, in 2wd trucks that doesn't really matter since they shouldn't be offroad.
Old 09-14-2006, 12:56 PM
Clay Henry Clay Henry is offline
Sooner Powerstroker Mod
Because he wants a lifted truck and thats what he has to work with at the moment....your right that was obvious.:bonk:
I wasnt planning on offroading-I just hate the fact that the 2wd sits so beepbeepbeepbeep low. Ive had lifted 4x4s in the past and it just felt better having a truck that sits tall. I doubt I'll even do it bc I was always the guy to give lifted 2wds a hard time in the past Just my thought process
