quick question - Ford Powerstroke Diesel Forum
Old 02-09-2008, 08:28 PM
quick question
I ahve an 05f2504x4 crew cab long bed and I have33x1.5r17 with a leveling kit and the tires look really small I was wondering if 35's would fit on my truck without rubbing? Thanks for the help
Old 02-09-2008, 08:32 PM
Rice Hunter
12.5 or 13.5 ? ?
They reccomend 35's w/no rubbing
Old 02-09-2008, 08:42 PM
12.50's would 13.50's fit ?
Old 02-09-2008, 09:55 PM
05 should fit 35's with a leveling kit, i had to go with a 6" lift on my 04 to run them..
Old 02-10-2008, 03:40 AM
My 35x12.5 20's mud grapplers would rub a bit with the 3" kit. So I would say no on the 13.5 width. But I now have 325/65 18's bFG A/T KO and they just barely squeeze by with no rubbing. I think a less aggressive 35 would work also.
Old 02-10-2008, 04:19 AM
Slacker
Feedback Score: 4 reviews
I have 33's with 13.5 inch width and they rub when turning... Unfortunately, that's just too wide even with a good bit of offset (like mine).
Old 02-10-2008, 04:37 AM
35 12.5 with the right back space on the wheel will fit most shops will test mount some for you to get the right wheel and the good shops already know what wheel it will take 13.5 will rub no matter what wheel you use
Old 02-10-2008, 08:18 AM
It's the bumps at almost full turn when mine would rub. Pulling into parking lots mostly. Going down the road and sitting there were not any problems.
Old 02-10-2008, 01:14 PM
thanks a lot guys I'll probably be ordering my new tires on Thursday with my check from plowing all this snow we have been getting up here in il this sct tuner with Looney tunes is really doin a number on this set of tires.
Old 02-10-2008, 01:23 PM
hey whoa now thats new info you left out if youve had a plow mounted you front is gonna sag more than everyone elses thats alot of weight out front it fatiges the springs and sags the front even after you drop the plow you better buy local and have em test fitted first that could very well cause you problems when the plow is off and almost a given that theyll rub when the plow is on
