DeeZee Tailgate Assist w Write up Lots O' Pics - Ford Powerstroke Diesel Forum
View Poll Results: Which Tailgate Assist is the better choice?
DeeZee Tailgate Assist 3 21.43%
Stabilus Tailgate Assist 3 21.43%
I'm a man, I don't need no stinking assistance with my tailgate! 8 57.14%
Voters: 14. You may not vote on this poll
post #1 of 32 Old 04-03-2013, 04:23 PM Thread Starter
Fantom's Avatar
Quoted: 12 Post(s)
Feedback Score: 4 reviews
So i figured it was time I did one of these. I bought the DeeZee tailgate assist from Amazon DeeZee model number DZ43203
Here's how your truck should look without the tailgate assist
Here's what's in the package
Bed Assist strut, thread lock, mounting plate, a "nutsert" and nutsert tool (it's just a molly that expands when the bolt tightens), a torx wrench and the instructions and a ball-mount screw (now that I think of it, this stuff sounds dirty.
You don't need those instructions, ball 'em up and throw 'em away
Hmmm...don't throw 'em away just yet
This is the "nutsert" and tool, here you need to make sure there's about 3/4'' between the head of the bolt and the washer
Find the predrilled hole in the left side of the tailgate near the hinge
Put the nutsert into the predrilled hole that you just found
Hold the nut with a 13 MM wrench and a hexkey/allen tighten the bolt until the "nutsert" fully expands.
Put some of the provided threadlock on the ballmount screw
Grab your ratchet with a 16mm deep well socket
Put the ballmount screw into the nutsert, tighten with the above mentioned socket
Next you're gonna remove the cable
With the provided torx remove the bolt that holds the cable
Put this bracket where the cable holder bolt thing was and put the bolt you took out, back in it
Put the cable back on and tighten the bolt, make sure the bracket is straight up and down
Snap on the top of the strut to the newly added bracket and the bottom snaps onto the ballmount screw
Almost done.
See this rubber guy here? Yeah he gets in the way of the strut and you can't close the tailgate, rendering this mod useless
Use an 8mm socket to remove the bolts from the back of the tail light, once you pull it off, find the 11mm bolts that hold that rubber stopper on. my bolts are really dirty
So long, rubber guy
Here it is without the rubber stopper
Once you've done that, close up your tailgate and enjoy your handywork
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #2 of 32 Old 04-03-2013, 04:46 PM
good job John. That video almost looks professional
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #3 of 32 Old 04-03-2013, 04:48 PM
portcity_gt's Avatar
Quoted: 1270 Post(s)
I've had one on my truck for a while and love it. I bought it from eBay for $33, then later found out oriellys sells them for $20
Also I didn't bother removing the rubber, I just pulled out my knife and cut the rubber part off.
03 cclb dually,6.0,arp studs,bpd oil cooler,bpd 6 phase ficm,bpd water pump,bpd all aluminum cac,all aluminum radiator,amsoil bypass oil filter,ipr high flow coolant filter,egr delete,livewire ts tuned by Vivian & tony,php ficm tuner,dc power 300-spx,Detroit trutrac,6" dual side pipes,07 front end,custom front bumper,shaved badges,led button roof lights,08+ mirrors,12 tailgate,13 rear bumper,13 tail lights,dropped I beams,custom rear 4 link w/bags,k5la train horn,24" alcoa's.
portcity_gt is online now
post #4 of 32 Old 04-03-2013, 05:00 PM Thread Starter
Fantom's Avatar
Quoted: 12 Post(s)
I had a camera crew out here and everything, if you listen carefully, you can hear the director say "perfect"
I found this on Amazon for $24 and I got it in 2 days
John
100,000 Miles
Fantom is offline
post #5 of 32 Old 04-03-2013, 05:28 PM
Quoted: 28 Post(s)
That video is pretty good. Where is the camera girl? Just need some narration with a mustang in the background ...! Lol
06 350 CCLB
Edge CTS
Up-Pipes by Cutting Edge
ARP's
Bulletproof EGR Cooler
Coolant filter
rentstdi is offline
post #6 of 32 Old 04-03-2013, 05:31 PM Thread Starter
Fantom's Avatar
Quoted: 12 Post(s)
I'll make a new video when Sarah gets home lol
John
100,000 Miles
Fantom is offline
post #7 of 32 Old 04-13-2013, 02:34 PM
BOlhausen's Avatar
I have one of these things and love it! I shaved my tailgate, and installed a popper. I push a button on the dash and the tailgate drops!
Good write up.
[/SIGPIC]
BOlhausen is offline
post #8 of 32 Old 04-15-2013, 05:45 PM
Island Dweller
Qholic's Avatar
Quoted: 57 Post(s)
Thanks for the idea! Just went to OReillys picked one up and installed it for less than 20 bucks
Shawn
2007 F-350 King Ranch FX4 LB Tow Boss DRW
SCT LiveWire, Atlas 80, WPE tunes, Blue Spring, Holders 175/30 injectors, KC Turbos Stage 2, Magnaflow Dual Tip 5", AMSOIL BMK-21, PMM Coolant Filter, Zoodad MOD, CCV MOD, AFE Pro Dry S OER Filter, Final Charge ELC, 08 style mirrors, SAP Diesel DD Solenoid, Derale Transmission Pan, Mishi CAC Tube and Boots, High Idle Mod, more to come..,
Qholic is offline
post #9 of 32 Old 04-17-2013, 08:33 PM
amdriven2liv's Avatar
Quoted: 4 Post(s)
I did also.
Thanks Fantom for posting.
2004 F350 6.0L CC LB 4x4 King Ranch
amdriven2liv is offline
post #10 of 32 Old 04-17-2013, 09:06 PM
PyroTekRob's Avatar
Quoted: 266 Post(s)
Great post! Im going to think about doing this as well.
2006 F250 Amarillo 4x4 CCLB - 194,xxx
SCT Livewire TS - Tunes from Vivian (Eco, Tow, Tow w/ JB, Looney)
B&W Flip over Goose neck / B&W Tow & Stow
Leveling Kit - Wildpeak AT 325/60R18
Sinister Diesel Coolant Filter
Garrett Powermax Turbo
DC Power Engineering 185amp Alt.
LED Interior lights, Reverse, and LicPlate.
Planned:
BDS 6"
LED Light upgrades
PyroTekRob is offline
