2 inch spacers.. Are they safe? - Ford Powerstroke Diesel Forum
Old 01-27-2008, 04:24 PM
Hey guys I have an 06 king ranch with a 2 inch leveling kit. I have 35 inch tires (toyo mt) that rub a little. I want to eliminate this with 2 inch spacers. Aside from rubbing I think it will look better with Front and rear kicked out 2 inches?? I was looking at these... eBay Motors: WHEELS SPACERS ADAPTERS 8 Lug Ford 2003-Newer F250-F350 (item 120213768359 end time Jan-28-08 17:06:42 PST)
Old 01-27-2008, 04:28 PM
You got me, I dont know but thought I'd respond. You could go with a bigger off set rim. Anyone else know?
Old 01-27-2008, 04:30 PM
i was told it is bad to use spacers on there big trucks. too much wieght. What are you going to use the truck for?? any hauling???
Old 01-27-2008, 04:33 PM
They are safe to use but can stress your wheel bearings and seals and cause premature wear. I would try to keep em to 1" if you can.
Old 01-27-2008, 04:37 PM
International Threat
Duallys come stock with a wheel spacer up front...
Old 01-27-2008, 04:46 PM
for real??? what size?
Old 01-27-2008, 04:51 PM
Im assuming wheels with +2 inch offset would also stress wheel bearings? I do occasionally tow a 8k boat and trailer.
