track bar - Ford Powerstroke Diesel Forum
post #1 of 11 Old 03-15-2013, 09:17 AM Thread Starter
track bar
Hi there,
I just fitted a 3" leveling kit to my truck, but the axle is now around an inch over to the right hand side(passenger side) I have done a bit of research and it appears this is normal and I could benifit from fitting an adjustable track bar to reposition the axle back to centre?
I just wanted to check that I am correct in thinking that this would resolve this issue?
cheers Phil
Phi1 is offline
post #2 of 11 Old 03-15-2013, 09:25 AM
Java's Avatar
Yessir that will fix your issue.
2011 6.7 F350 - Dads
2009 6.4 F350 - Brothers
2007 6.0 F350 - Mine
1997 7.3 F250 - Farm Truck
Java is offline
post #3 of 11 Old 03-15-2013, 09:51 AM
bkingsoda's Avatar
I'm having the same issue. I might try flipping the track bar this weekend to see if that solves it. I have a 2.5 level so I'm only about 1/2 to 3/4 offset. Figured its a free fix, so its worth a shot.
2005 Lariat ccsb
ARP studs
Performance Machine egr delete
Performance Machine coolant filter
Sinister intake elbow
Metal cold side CAC
4" turbo back straight pipe
SCT SF3 tuned by Innovative
Blue spring and zoodad
Pioneer touch nav and full system
2.5" level with 35's
bkingsoda is offline
post #4 of 11 Old 03-15-2013, 10:09 AM Thread Starter
I got the 3" inch level so it's just under an inch to the right, but it's making the spring touch the metal casing so I want to get it resolved asap! Any suggestions on the track bar to buy for an 05 f350?
Phi1 is offline
post #5 of 11 Old 03-15-2013, 10:21 AM
bkingsoda's Avatar
I looked them up earlier, BD has one for like $265 with free shipping. Just Google superduty adjustable track bar. Good luck. I'm glad mine isn't touching the frame. Its close though, probably why I hadn't noticed until now. Just tired of the wobble on the highway.
2005 Lariat ccsb
ARP studs
Metal cold side CAC
post #6 of 11 Old 03-15-2013, 10:21 AM Thread Starter
Here is a few pictures,
I found this one on ebay but it says it's only to 04 mines an 05 so I guess it won't fit!
http://www.ebay.com/itm/3-99-04-Ford...39978e&vxp=mtr
also what is the name for the bush that you can see is split in picture 2 top right corner and picture 3 on the steering arm?
Phi1 is offline
post #7 of 11 Old 03-15-2013, 10:41 AM Thread Starter
I called the company I bought the leveling kit from and they said they have had this before but not very oftern but they said they sell a spacer that will lower the bracket meaning this will shift the axle back over. This option is $40 or I guess around $200 for an adjustable track bar.
Phi1 is offline
post #8 of 11 Old 03-15-2013, 10:53 AM
bkingsoda's Avatar
$40 isn't bad. I've never seen lift spacers under the spring. That "bush" you're asking about is the drag link ball joint. Not sure if you get only the ball joint. I'm just going to buy a new drag link to install with new tie rod ends that are in my tool box. Only want to take it apart once. Mine is split too, but so are most of the ball joints in the steering. Haha.
2005 Lariat ccsb
ARP studs
Metal cold side CAC
post #9 of 11 Old 03-15-2013, 11:01 AM Thread Starter
I think I am going to get the adjustable one so it can be dialed in 100% the spacer under works quite well, I maybe should have just bought a 3 inch progressive lift.
Phi1 is offline
post #10 of 11 Old 03-30-2013, 01:11 AM Thread Starter
Just wanted to let everybody know that helped and for future reference the bd adjustable track bar worked perfectly, the axle is now dead centre and the truck drives great!
Phi1 is offline
