hood will not pop up - Ford Powerstroke Diesel Forum
post #1 of 14 Old 03-13-2013, 08:22 AM Thread Starter
I ahve 2006 F350 6.0, I just bought it and the problem im haveing is when I pull the hood release nothing happens. I have to have someone hold the release out while I go and lift the hood up then I can reach in flip the lever and open the hood. Is this beacuse i need new lift supports ? the hood stays up fine when i get it open but you need to people to open the hood.
ford719 is offline
post #2 of 14 Old 03-13-2013, 08:22 AM
2000-7.3L's Avatar
Feedback Score: 10 reviews
Latch might be sticking! Its a ford thing LOL
2000-7.3L is offline
post #3 of 14 Old 03-13-2013, 08:26 AM
SuperCrutyPS's Avatar
Quoted: 347 Post(s)
Garage
Squirt some WD-40 or equivalent in there to see if it frees up the latch. Try the easy stuff first.
Owner | Operator: Darryl
My Truck Garage:
Tow Toy Garage :
United States Navy - IC2 - '76-'80
SuperCrutyPS is online now
post #4 of 14 Old 03-13-2013, 08:35 AM Thread Starter
I will try that tonight thanks
ford719 is offline
post #5 of 14 Old 03-13-2013, 08:36 AM
2000-7.3L's Avatar
wd-40 or PB Blaster
post #6 of 14 Old 03-13-2013, 09:00 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
It could also be out of alignment.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #7 of 14 Old 03-13-2013, 11:47 AM
if I pull mine it clicks but doesnt pop up I just have to lift it until it stops at the catch point then move the lever to get it to go all the way up
KCCO
Paul Devereux
2005 FX4 Lariat Dark Shadow Gray
AirRaid Filter, 6 inch Pro Comp Lift. 17 inch Mikey Thompsons with 35 inch Nittos, sinister coolant filter, MBRP 4" straight pipe, 6K HID, Zoodad, SCT with tunes from Vivian (Looney and Looney fuel) and Tony, dashboss with EGT and FP, 08' tail lights, blue spring, lowes CCV mod, 03' turbo
Soon... coolant flush.
DEVERO2 is offline
post #8 of 14 Old 03-14-2013, 02:57 AM Thread Starter
Thats what mine does, trided Wd-40 but the same problem, I see the rock auto has new lifts for 11 or 12 dollars so I may get a new set and see if that works. the hood gaps look ok and I cant see any thing on the latch where it looks like its rubbing where something is out whack
ford719 is offline
post #9 of 14 Old 03-15-2013, 04:35 AM
ctrow89's Avatar
I just replaced my lift supports 2-3 months ago because I was having the same issue. It didn't fix the problem on my truck completely. Sometimes it will, sometimes it doesn't pop up. It does however finish opening a lot faster and has a noticable difference, so it could be a combination of both. I haven't tried WD-40 yet because I've been gone.
2011 Ford F-250 CCSB Lariat
-Bone stock
**Picture to Come**
ctrow89 is offline
post #10 of 14 Old 03-15-2013, 07:08 PM Thread Starter
well i guess i will try lubeing up again and see if works this time
ford719 is offline
