difference between a 99-04 and a04-07 front bumper - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-11-2013, 10:11 AM Thread Starter
longdp27's Avatar
I have a 06 f250 and found a decent deal on a bumper that fits a 99-04. can anywone tell me the difference in the fit of these?
longdp27 is offline
post #2 of 6 Old 03-11-2013, 10:38 AM
Chapter Director
Rammstein1224's Avatar
Quoted: 5 Post(s)
Feedback Score: 5 reviews
Well when most people do a 99-02 to an 03-07 swap they have to trim the bottom of the 03-07 grille slightly to fit on a 99-02 bumper. So im guessing you will have to trim your grill if you want it to fit.
Local Jackass member Pat
Battle cry of every 6.0 owner out there
Originally Posted by access_max View Post
With the issues fixed a 6.0 can run circles around a 7.3.
2000 F-350 7.3L ZF6
Standard 7.3 mods
SCT tuned
8" Fabtech lift 13" total
5:13 Gears
46" Goodyear MVTs Military takeoffs
Bushwacker Cut-Out Fender Flares
Ranch Hand front and rear bumper
On-board air W/Semi horns
1995 F-350 7.3L E4OD DRW
Standard 7.3 mods
PHP Hydra W/Tony Wildman tunes
160/0 Injectors
T-500 HPOP
E-fuel Conversion
West Coast mirrors
Rammstein1224 is offline
post #3 of 6 Old 03-11-2013, 04:45 PM
shawnb99's Avatar
the 05-07 bumper is a little lower with a paintable cap tot ake up space under the headlight....
like mentioned, the 05-07 grille is little longer from a head on shot.....look on ebay for the grille that updates the 99-04 to the 05-07 and you will see the lower crossbar is way thinner.
04 F-250 CCSB 4X4 6.0L Auto, tweaked by GEARHEAD
follow link to truck for sale
shawnb99 is offline
post #4 of 6 Old 03-11-2013, 04:57 PM Thread Starter
longdp27's Avatar
could i just use a 2004 gril. I kinda like those vertical grills
longdp27 is offline
post #5 of 6 Old 03-14-2013, 06:10 PM
shawnb99's Avatar
yes, if you run the 99-04 bumper...of course you can modify either.
you can
1. trim the lower portion of an 05-07 grille to fit the 04 bumper
2. you could trim the bumper top on the 04 to allow the vertical height difference to clear
3. you could space the 04 bumper outward enought to clear your grille
shawnb99 is offline
post #6 of 6 Old 03-14-2013, 06:52 PM
USAFBowman's Avatar
you can
4. you could also purchase the MKM customs grille for the 99-04 to mimic your 05 grille. (this grill is pre trimmed to the size to fit the 99-04)
USAFBowman is offline
