4x2 Rims fit 4x4 Truck??? - Ford Powerstroke Diesel Forum
Old 01-14-2008, 04:18 PM
Talking 4x2 Rims fit 4x4 Truck???
i'm looking at buying a set of 06 4x2 stroker rims for my 05 4x4 stroker. i'm not familiar with compatability and was wondering if this would work?? i know the lug pattern should be the same, but was thinking the x2 to x4 change may be an issue. thanks in advance for the help!
Old 01-14-2008, 04:19 PM
duct tape & zip ties
The rears will most likely fit. I think the fronts are the same. But I maybe wrong. If you are buying them locally. Then see if they will fit if they do then make the deal. If they do work then you may end up needing to use your old center caps for the fronts.
Old 01-15-2008, 03:49 PM
thanks for the help bigcountry. i was thinking that all of them would have to be the same for tire rotation and spare tire use. i'm waiting on pics and maybe that would clear it up
