Will these wheels fit - Ford Powerstroke Diesel Forum
post #1 of 9 Old 03-10-2013, 07:04 PM Thread Starter
I have a 04 king ranch 4x4 and a guy has these wheels and nitto terra grappler tires for sale. They both have the same lug pattern from what I have researched but not sure about the offset. I have found different opinions on that. Just wondering if they will fit because I can get a good deal on them and I need tires. They have the open holes on the front center caps to fit my manual locking hubs through. Just would like to know because it is close to a hour drive to go get them. thanks
944own is offline
post #2 of 9 Old 03-10-2013, 07:23 PM
BIG Laing's Avatar
You need between a 0 offset and a -12 offset for stock sized wheels to fit on a stock height '04 and older truck.
So find out what offset they have before buying them.
2013 Lariat Eco-Boost F150 Super Crew 4x4 20K Miles. Max-Tow 3.73's, luxury package. Amp Steps, Raceline Raptor Wheels, Bak-Flip, and much more.
BIG Laing is offline
post #3 of 9 Old 03-10-2013, 07:26 PM Thread Starter
Yea I have looked around some more and I think I would need wheel spacers that would cost close to $200 to make them work. If it was a 05 I think they would bolt right up. I sure wish they would fit. thanks
944own is offline
post #4 of 9 Old 03-10-2013, 07:27 PM
BIG Laing's Avatar
So they have a + offset? Like +20 or +40?
post #5 of 9 Old 03-10-2013, 08:08 PM Thread Starter
Im really not sure just going by what I have read you need the spacers to put wheels from anything 05 or newer on anything 04 or older. Just hoping someone had some first hand experience that could confirm or deny this. thanks for your help
944own is offline
post #6 of 9 Old 03-10-2013, 08:16 PM
BIG Laing's Avatar
Yes if the wheels your are looking at are stock 05+, they have a +40 offset. 04 and older has a 0 offset stock. 40 mm is about 1 3/4" so you would need 2" spacers.
If you get spacers buy a popular brand that are hub centric and wheel centric. Do NOT buy lug centric spacers!
post #7 of 9 Old 03-10-2013, 08:18 PM Thread Starter
Thanks for the help I think im gonna pass on the deal. Guess I will just be buying tires for what I have. I see you have 295 70 18 in your sig. Can I fit that size without a lift or rubbing. I have 275 70 18 now. thanks
944own is offline
post #8 of 9 Old 03-10-2013, 08:47 PM
BIG Laing's Avatar
I am not sure on your truck sorry. I know they fit on 08+.
Mine are 34.5x11.8 your current tires are 33.5x10.8
Do you have 1/2" clearance in every direction? I would imagine you would barely rub the leafs at full lock.
post #9 of 9 Old 03-15-2013, 11:47 PM
Sno-Mow's Avatar
Re: Will these wheels fit
I've got 18" 06 rims on my 03 they fit but rub on the leaf springs if you turn too sharp.
2003 F250 6.0l
281,000 miles and counting
EGR Cooler Delete, A1 Studs, 3.5" Down Pipe, 4" Straight Pipe, Turbo Rebuilt, New OE Heads, New HPOP, New Injectors
Blizzard 8611PP
Because you won't push it with a gasser!
Sno-Mow is offline
