hid questions - Ford Powerstroke Diesel Forum
Old 03-09-2013, 05:42 PM
hid questions
not sure if im in the section for posting this so please change to the right section...
I have a 05 f250 Harley edition and im ordering hid's from ddm tuning
thinking of the 55watt 8k for fogs and headlight..
questions is will the 55's melt the headlight cause of the heat the make?
did you buy the additional relay harness for the 55's
should I do the 55 heads and 35 fogs or just go with 35watts all together...
I drive through where theres a lot of dear so I would like to see them before its to late...
I have done some reading and it seems like 1 person has a melted fog and 100 have no problems..
Old 03-09-2013, 05:52 PM
Real Men Love Jesus! <><
I have 55 watt head and fogs. I have had no issues in 2 years with them, I'd go 55 in both,,,.,
hid questions
The HIDs really do not get hot at all so you should have no problems with melting. I'd recommend 6k they're the most functionally bright HID you can get
Old 03-09-2013, 06:07 PM
I was going with the 6k 35watt. but they say if you want the 6k look with the 55 you have to go to 8000k.... I just want them to have the slightest tint of blue
I guess I should of asked what color everyone would recommend for a k rating
Old 03-09-2013, 06:29 PM
If its slight blue you want go 8000k. Mine are 6000k and they are pure white.
Old 03-09-2013, 06:35 PM
are you running the relay harness's for them?
Old 03-09-2013, 06:41 PM
No relay harness. I have the kit from retro solutions. (Site sponsor ) and they have the wiring to plug and play. I just ran it to a switch off the hot from the battery. Make sure you use good grounds. Bad ground will give you intermittant issues from the get go.
Old 03-11-2013, 07:04 PM
awesome thanks.. I guess ill try with no relay and see if I have any problems.. still worried im going to melt my fogs lol
Old 03-11-2013, 07:15 PM
Once you go black......
Send a message via MSN to CanadianDiesel
False...any HID gets hot after being on for a little while, specially the 55s. Higher wattage = more power draw and more heat.
I do agree with the 6k, I see people here with 10k+ and I want to run them into the ditch
To the OP;
Be careful of any wiring harness that comes with the kit (If you do decide to go that route), as they often use wire gauge that is too small, and a fuse that is rated way too high. I learned that the hard way...
Old 03-11-2013, 07:31 PM
Yeah it's a Turbo Diesel
Feedback Score: 8 reviews
hid questions
4300k is the brightest and serves the best lighting. I prefer the 6000k tho, it's more of a fluorescent color than white, but not blue. Your best way to do HIDs is to NOT put them into stock reflector housings. The true and best way to run HIDs is to do a retrofit hid projector set up, which I have done and a few others have done too. Check the link in my sig for more info.
For about a $100 ish more bucks you can do a retrofit urself and have 10000 times better lighting system. Or have Cary at CT Performance do it for you. He's a site sponsor and does a great job.
Sent from AutoGuide.com App
