- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
| 6.0L Exterior Discussion Body and Accessories Talk |
Leveling Truck
I was wondering if leveling out my F250 is worth it andwould it work if I have the FX4 package. I was just reading here and elsewhere that using certain lift components are worse than others. I was just reading about the Rancho & Skyjacker kits, and the Rancho was around $900 because it used HD radius arms instead of just raising the coil height and adding leafs (skyjacker) which was only $275. Would the rancho be more worthwhile because it is more money or would it not matter. I'm not really planning on lifting my truck, but wouldn't mind leveling it out, however I was thinking that that may have a bad effect if/when I get my plow put on?
Thanks. -BG06. |
| Sponsored Links |
Wouldnt worry about anything...2.5" leveling spacers keep your suspension in tollerance for alignment and as long as your not seriously off roading the stock shocks should be ok. Adding a plow will not affect anything. Rough Country makes a 1.5" replacement spring if you dont want to go the full 2.5", I believe thy run about $150?
Well, I talked to rockymountainsusp.com and they steered me towards the Revtek 2.5 leveling kit, saying that it gives the most OEM ride. However the other companies that I talked to (Rancho & Skyjacker) both said that there is no way to maintain the stock ride after you lift it. I know that is true when you do a 6 inch, but I didn't know a 2.5" would do that. -BG06. |
Its gonna run you between $900-$1200. Rancho has the most expensive. Rough Country though has a 3" for $440. I don't know much about them, but it uses front coils and rear blocks, and allows 35s to be put on, however w/ a dually you're going to be spending more on rubber than on the lift, so I'd get something you're happy with. Check out these guys: www.rockymountainsusp.com They've helped me in the past. -BG06. |
it takes about 1 hour max to do this job, jack the truck remove bolts in top of coil springs and remove shocks as well as release brake line hangers for travel purposes only. Let front axle down and remove factory spacer install new spacer and jack axle back up. ride doesnt change at all, I am doing another one on Saturday for a friend. I recommend replacing shocks as well some applications do not require it I am pretty sure yours does. Perfect ride and less than $225.00 . in my opinion you cant beat it.
The only problem other than the ride is asthetic, I basically don't want to have a truck w/ the 3 stock Rancho 5000s in the rear and 2 new ones of a different brand in the front. The Revtek company has their shocks that look exactly like ranchos, but have their logo and a black boot. They said that they'll leave the logo off, and said for me to just swap the boots witht he stock ranchos and I'll be fine.
-BG06. |
| Sponsored Links |
